HELP!! Oil in coolant tank... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-18-2014, 11:19 AM Thread Starter
LOW96HB's Avatar
Ok 2000 F350 7.3. I was doing a oil/tirepressure/water over all checkup sat and when I took the cap off the coolant tank all I was was a black sludge. I stuck a rolled up rag down into the tank and all I brought out was a black sludge. So it seems that oil is getting into the antifreeze at some point or could it be fuel in my coolant? There is no sign of water in the oil. Is this a common problem, or could I have a major issue?
KEEP HONKING, I'M RELOADING.
2000 F350 Lariat crew cab 4x4 7.3L
SuperChip ( plug in type )
Banks Big Head wastegate
LOW96HB is offline
post #2 of 8 Old 01-18-2014, 11:30 AM
blue99stroker's Avatar
Quoted: 283 Post(s)
most likely your oil cooler finally went.
the seals go bad when it gets cold.
you can either rebuild it (70 bucks) or buy a new one.
i think dieselorings sells everything you need
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #3 of 8 Old 01-18-2014, 12:15 PM
schlutzer's Avatar
Quoted: 18 Post(s)
X2 on oil cooler. Don't be too alarmed. It's a fairly simple job
The reason you get coolant in the oil but not the other way around when the oil cooler fails is because the oil is at a higher pressure in the cooler. So if the internal seals fail the oil pushes past to where it shouldn't be.
You will also need to replace your coolant flushing the block many times
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 8 Old 01-18-2014, 12:44 PM
Quoted: 283 Post(s)
ya i forgot to add in the flush takes a while lol
post #5 of 8 Old 01-18-2014, 03:55 PM Thread Starter
LOW96HB's Avatar
Alright nice...I think. Is there any specific flush that you all recommend, or just use water or ???? I have been looking on utube and the net and It doesn't seem like too bad of a job, just takes time...Thanks guys...
LOW96HB is offline
post #6 of 8 Old 01-18-2014, 04:14 PM
Simple green. had to use 7 gal.'s to get it all cleaned out. found out thats how our local ford dealers do it.
SUPERDUTYMIKE is offline
post #7 of 8 Old 01-18-2014, 04:17 PM
Note: regular household water can be used for flushing and distilled water when you refill your clean system. Theres alot or great flush vids on youtube.
post #8 of 8 Old 04-11-2014, 04:40 PM Thread Starter
LOW96HB's Avatar
Well guys I finally got around to fixing the seal leak. I ordered the parts back in Feb and due to the cold weather and other thing that seems to keep me busy I fix my truck this afternoon. Yes me and my 11 year old son fixed my truck...He was there for 2 main reason..1. to hand me tools. 2. To keep ole dads mouth from running away when stuff just didn't go like the multiple videos that I watched on how to do this " simple " job...and yes he got his hands dirty too.. Thanks for the input back when I started asking about this. Also it took us about 3.5 hours.....
LOW96HB is offline
