starts fine runs fine but random power loss - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-16-2014, 09:46 AM Thread Starter
Lilsinkko's Avatar
my 7.3 runs and starts great but randomly looses power and CEL comes on and sometimes goes back off and sometimes i have to shut the truck off and turn it back on. which can be a hassle going down the road. i have check most all plugs and shimmed valve cover connecters. i am now at a loss.
the truck is chipped with banks and straight piped
CODES
P1316
P0340
P0470
Lilsinkko is offline
post #2 of 6 Old 01-16-2014, 09:59 AM
ADMIN AND TECH
SCUFFY828's Avatar
no codes at all, cam sensor ,, throttle pedal,, icp sensor , ipr regulator , several things it can be , need to monitor data
ITS STOCK
SCUFFY828 is offline
The Following User Says Thank You to SCUFFY828 For This Useful Post:
Lilsinkko (01-16-2014)
post #3 of 6 Old 01-16-2014, 10:14 AM Thread Starter
Lilsinkko's Avatar
Sorry forgot codes just add thanks
post #4 of 6 Old 01-16-2014, 10:20 AM
ADMIN AND TECH
SCUFFY828's Avatar
p1316 is definitely a electrical code for injectors , need to run a buzz test to see what you get from that , p0340 is cam sensor code
ITS STOCK
post #5 of 6 Old 01-16-2014, 10:34 AM Thread Starter
Lilsinkko's Avatar
Hey scruff thanks for the help but what is a buzz test?
post #6 of 6 Old 01-16-2014, 11:51 AM
ADMIN AND TECH
SCUFFY828's Avatar
a buzz test is a injector electrical test that can be ran with an adequate scanner that will monitor data and run functional tests , the p1316 is a pcm code which tells you that you have injector wiring issues , a buzz test will breakdown which cylinder or multiple cylinders that are throwing the p1316
ITS STOCK
