96 7.3 shutting off when going up hill - Ford Powerstroke Diesel Forum
post #1 of 14 Old 10-02-2008, 03:38 PM Thread Starter
powerstroke6's Avatar
my dad has a 96 7.3 and it shuts off going up hill. It just starts bogging down then quits. Have any ideas what could be wrong?
powerstroke6 is offline
post #2 of 14 Old 10-02-2008, 03:46 PM
(1) Low on fuel
(2) Low on oil in motor
Diesel Monkey is offline
post #3 of 14 Old 10-02-2008, 03:49 PM
sldghamr's Avatar
it just shuts off or does it lose power??
if you haven't replaced the CPS, does so anyway, cheap fix at the Ford dealer.
if that doesn't do it, check the oil level in the HPOP.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #4 of 14 Old 10-02-2008, 04:07 PM Thread Starter
It shuts off and most of the time it wont start back till you let it roll off.
It has a new CPS on it.
post #5 of 14 Old 10-02-2008, 04:08 PM Thread Starter
how do you check oil level in the HPOP?
post #6 of 14 Old 10-02-2008, 04:53 PM
sldghamr's Avatar
don't know, never done that before. if you wait long enough, someone will let you know.
sldghamr is offline
post #7 of 14 Old 10-03-2008, 09:18 PM
97 7.3shutting off
Hi,the hpop is at front of engine about the size of a big phone book has a
set screw on top also on right side of square top,takes a 1/4" drive to get
it out,it is also right behind the fan.
WHISKY6 is offline
post #8 of 14 Old 10-05-2008, 04:31 PM Thread Starter
do you take the plug out in the side and if oil runs out your good. if not what kind of oil do you put in it?
post #9 of 14 Old 10-06-2008, 07:02 AM
hpop
hi,the procedure to change oil in hpop is on miantains post i believe thats
where i saw it.
I used a grease gun suction type to pull oil out of hpop it takes a while
but it can be done i believe there are marine suction pumps that are
battery operated i could not find one in my area as of yet.
WHISKY6 is offline
post #10 of 14 Old 10-07-2008, 03:34 PM Thread Starter
i check the oil in the hpop and its full do I still need to change it?
