Hissing when cold - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-18-2006, 11:42 AM Thread Starter
Log Dog's Avatar
Hissing when cold
My engine is making a strange hiss when its cold (even after I let it warm up for 10 min) It seems to lose power as well, but if I get on the throttle it goes away. If I let up it starts again. It goes away after about 5-6 miles of driving.
Any help would be great!!
Log Dog is offline
post #2 of 10 Old 11-18-2006, 12:01 PM
LTJDS
LTJDS's Avatar
Possible Exhaust leak that can effect turbo performance, but when the motor warms up and the metal expands the leak is minimzed and the sound dissapates and power is restored. This is my guess , I have exp this type of thing before.
I recently pulled my 7.3L PSD for a rebuild and my mech and I found an exhaust leak which was coming from the exhaust tubes that feed the drive side of the turbo. We noticed carbon depositis around the pipe and flange. This indicated a possible leak of exhaust gas pre turbo.
Good Luck.
06' F350 FX4, Mickey ATZ's, NOS+, 5" Xhaust, AFE Stg 2,Sneaky Pipe, SCT LWire w/180Hp Tune,CFM+LM Carbon Fiber, 4 AutoMeter Cobalt Gauges, MagHytek Trans & Diffs, FS-2500, LED Lights, T-rex Grill, Zoodad, Clifford Av Guard 5.1 Alarm w/ GPS. AND..2 much 2 List.
WON 1st Detail, & 1st Late Model Daily, @ 07' Truck Nat's, & Won 1st Best Modified @ 07' Ford Power Festival & Won 1st Modified,
& 2nd Highest HP @ SSS 07'
Thanks 2
LTJDS is offline
post #3 of 10 Old 11-18-2006, 01:00 PM
lawman349's Avatar
no fear.
its your Exhaust Back Pressure Valve (EBPV). And it sounds like it is working properly. It closes off some exhaust, puts a load on the motor, and help the diesel warm up.
sounds like all is well, but if you want to conduct a test to make sure, read this thread...
Turbo Surge
someone goes into detail about how to disconnect the ebpv. it the sound goes away then i was right...LOL
2003 F350 SRW CC 4x4 6.0L
Coolant Bypass Filter w/ Cat ELC
Amsoil Oil Bypass Filter
Hypertech MaxEnergy / Bully Dog Outlook
Cat and muffler DELETE!
Icon 2" leveling kit
Mickey Thompson MTZs
ARP Head Studs / New Ford OEM HGs
New heads
Sinister Diesel EGR Cooler
Blue Spring Upgrade
New HPOP STC connection
lawman349 is offline
post #4 of 10 Old 11-18-2006, 03:54 PM
tstroke's Avatar
agree with law man hiss is normal when cold the colder the more hiss you should hear it with out a mufler sounds like a jet. cool
tstroke is offline
post #5 of 10 Old 11-18-2006, 04:00 PM
HardLuck Case of the Year
Ditty's Avatar
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Word!!!
I thought it was a vaccum leak at first, but then I realized I still have my EBPV connected and then took note of the cold. 1+1=EBPV!!!
DITTY
Brisco:-White 2000 F-350 PSD CrewCab/SRW/LongBed/4x4/6spd Manual/HUGE Powerstroke.Org Vinals!
Favorite Mods: Baby-seat mod/Girlfriend delete/6pos on Xtreme!
Repairs since bought: both batteries/alternator/3 transmissions/4 clutches/entire front axle/new steering stabilizer/power steering pump
Still broken: cracked windshield/all glowplugs/glowplug relay/4WD still out/trailer harness no power
Current Best: 16.149@84.13MPH (Est.7800lbs)
Ditty is offline
post #6 of 10 Old 11-18-2006, 05:52 PM
just a number
igoslow's Avatar
In cold weather mine sounds like a mosquito sprayer until I touch the brakes.
2006 Dually
igoslow is offline
post #7 of 10 Old 08-20-2007, 08:37 PM
99.5stroker's Avatar
Not to thread steal but im having a similar prob with my truck, BUT, it dos it with the key in the run position BEFORE i even start the truck. searched the forums for 2 days with all types of (blank) leaks and have found nothing. Any ideas guys
99.5stroker is offline
post #8 of 10 Old 08-21-2007, 02:26 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
it could be the vacuum pump if its doin it before you start the truck. does it sound like its coming from the passenger side fender area
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #9 of 10 Old 08-21-2007, 12:05 PM
DIESEL RACER's Avatar
99.5, the hissing sound could be the vacuum pump, or you could be hearing fuel and air being pushed through the filter bowl and pressure regulator.
DIESEL RACER is offline
post #10 of 10 Old 09-02-2007, 11:07 AM
Yeah, i ruled out the vacuum pump.
It is comin from the filter housing area....any common areas on this thing that i could start looking at. It squeals sometimes and other times i can just hear a leak of some sort. NO large fuel leaks. Could an air leak cause my truck to run hotter (egt's)? It makes the sound until i crack open the yellow drain thingy and let alittle fuel run out. Like my technical descriptions?
Any ideas guys???
