Fuel Filter Question. - Ford Powerstroke Diesel Forum
Old 11-16-2006, 06:49 PM
Send a message via ICQ to rtstanger
Question Fuel Filter Question.
I have a 2001 F250 with a 7.3 Power Stroke. I bought a fuel filter from Napa Auto parts. This filter came with two o rings, the tapered one and a round one. The filter I removed only had the tapered one. I couldn't find a place for the other one and I am concerned why it was included. Was I supposed to use the othe one?
Thanks for your help!
Old 11-16-2006, 07:15 PM
Powerstroke Techie
It goes around the bottom of the plastic part with the grove in it
Old 11-16-2006, 08:04 PM
Talking
Thanks so much for the quick reply!
Old 11-17-2006, 10:05 PM
Question
have you had any problems with the tapered seal leaking. mine starts leaking about every 5000 mi
Old 11-26-2006, 05:30 PM
No, haven't had any leaks. However, I changeemine every 3000 miles, that might be why.
Old 11-26-2006, 06:23 PM
o ring
if you cant find the round o ring,on the filter you took out, you need to look in the filter bowl, sometimes it comes off down in there when you pull it out,
Old 11-26-2006, 06:27 PM
Jon
Guest
Posts: n/a
The only time I have ever
seen them leak is when they are upside down.
