7.3 Problem Solution Chart - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 18 Old 12-11-2013, 03:43 PM Thread Starter
Joe0816's Avatar
Okay guys, I have been trying to learn all of the problems and solutions, well probable solutions, and I thought it would be awesome if someone made a chart or something like such that shows the problem and solution or possible solutions, like the following:
Fuel in Coolant..............................Injector Cup
Oil in Fuel.....................................Injector O Rings
Low Tire Pressure...........................Nail in Tire
Okay the last one was sarcasm, but you get the point. Is there a similar chart out there and I searched the wrong things, or what? Thanks!
If you can think of any more, post it on here and I will add it. An updated chart will be posted daily.
2001 F250 ECLB 7.3 PSD 219,000 miles
S&B Intake
Flo-Pro 5" SS Exhaust
ISSPRO EV2 Boost, Pyro, Trans
David Lott Tunes
Riffraff HPx, FRx & AIH Delete
Resse Gooseneck Hitch
Non-EBPV Turbo
Joe0816 is offline
post #2 of 18 Old 12-14-2013, 04:21 PM
lookin4myPSD's Avatar
There is sort of a culmination of everything in the 7.3 tech files, but to my knowledge, there does not exist a master-of-everything chart for diagnosis and symptom identification.
I love the idea though. Maybe we could make this into a thread that anybody can post on, adding little tidbits of information.
Like...loss of coolant. This can be blown head gaskets! It's common knowledge to the everyday powerstroker, but to the newb, not so much.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #3 of 18 Old 12-15-2013, 06:40 AM Thread Starter
Joe0816's Avatar
Good to hear someone else gets what Im talking about! If I get a chance later I will start a chart, and if others would, make your own and I will add them to each other, and as the more people post, the larger the chart gets! Should I sort them by like Head gasket- burning coolant, coolant in oil or should I do problem then what it is like this, coolant in oil- headgasket coolant being burnt- headgasket.
S&B Intake
David Lott Tunes
Non-EBPV Turbo
Joe0816 is offline
post #4 of 18 Old 12-15-2013, 06:51 AM
I like the idea of sorting into categories by the root cause. So, set up a category for "Head gasket symptoms" and then a compiled list of any possible symptoms (and treatments if we want to go that far). That way, anybody could simply search the thread for their keyword, and it would point them to the category in which the problem would reside.
Early 99 F250 ECLB,
post #5 of 18 Old 12-15-2013, 07:16 AM Thread Starter
Joe0816's Avatar
That's what I was thinking, but as far as treatments, It should be pretty obvious, such as replace headgasket or injector cup, orings, etc. Most of it is R&R
S&B Intake
David Lott Tunes
Non-EBPV Turbo
Joe0816 is offline
post #6 of 18 Old 12-15-2013, 07:48 AM
I'm on board with this. Give me a holler if you need anything!
Early 99 F250 ECLB,
post #7 of 18 Old 12-15-2013, 08:54 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
BUT, what you Really need is a Flow Chart. To say "IF This,,, Then That" is over simplifying complex mechanisms. We all wish it was that simple, and of course there Are the "Most Likely" solutions that should be explored first for many issues. Unfortunately, Far More often you need to go through a Step-by-Step diagnosis that, requires some skills, understanding, and the right tools too
Long Live Fonzie for making us think you just gotta know where to Bang with your fist!
NoRalPh is offline
post #8 of 18 Old 12-15-2013, 09:01 AM
This is gold right here^^
Early 99 F250 ECLB,
post #9 of 18 Old 12-15-2013, 12:04 PM Thread Starter
Joe0816's Avatar
Well yeah it isn't a definite answer to the issues, just places to look first, a good reference point.
S&B Intake
David Lott Tunes
Non-EBPV Turbo
Joe0816 is offline
post #10 of 18 Old 12-15-2013, 12:07 PM
The "powerstroke.org table of contents"
Early 99 F250 ECLB,
Tags
chart , problem , solution , solutions , table
