Please Help Turbo Damage! - Ford Powerstroke Diesel Forum
post #1 of 19 Old 12-10-2013, 04:36 PM Thread Starter
Let me begin by saying this is my fault.
That said. I have an issue and I could really use some outside help. So leaving the gas station the other night I went to get out of the center lane and I had to step on it to pass a car (I do have a Flashpaq 1855 on Performance mode) truck is stock with 207K miles. The truck began to take off then it fell on its face. After I noticed that the truck sounded like a vacuum cleaner. I got home and popped the air box. The air filter was pulled up. Bought the truck in August and never checked the filter (hence this is my fault everything else checked out new and thought a tune up was just done) which was caked in dirt . The filter was still complete. The next morning i got a new filter and drove to work. Still sounded like a vacuum. I pulled the intake and found all my compressor blades chewed with some contact marks. I ordered a new WW. The housing is not in too bad of shape. SO after all that my question is can i get away with just changing the wheel or am I in for more fun? No real excessive play in the turbo shaft and spins freely. Thanks!
JayFalcy is offline
post #2 of 19 Old 12-10-2013, 04:44 PM Thread Starter
Here are some pictures.
ID:	211618   Click image for larger version
ID:	211626   Click image for larger version
JayFalcy is offline
post #3 of 19 Old 12-10-2013, 04:48 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
wow! thats some serious chewing. all that metal is in the engine now. pull the whole turbo and clean it extremely well before you put the new wheel on. do an oil change before you start that thing again and after about 500 miles change the oil again. ( though technically it shouldnt have let metal into the oil being that it went through the intake but it could still cause other damage that could send metal into the oil ).
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #4 of 19 Old 12-10-2013, 05:05 PM
schlutzer's Avatar
Quoted: 18 Post(s)
My jaw dropped when I saw that...
Pray you don't need an engine... remove your ENTIRE intake system and clean it, intercooler too.... get as much of that metal out of there as you can...
Hope for the best,
for comparison... look at how much metal is just gone... looks like you sucked in a rock or something
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 19 Old 12-10-2013, 05:26 PM
turbotibbo's Avatar
wow , good advise above
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #6 of 19 Old 12-10-2013, 05:53 PM Thread Starter
First of all, thanks for your replies so fast. Yea I was thinking a rock as well. I am kind of hoping that it all got stuck at the beginning of the intercooler. Drove it about seven miles since the incident and no smoke from the exhaust so I am hoping I dodged a bullet there. Is the turbo hard to take off? I do have the compressor side off already. Just the wheel is still on.
JayFalcy is offline
post #7 of 19 Old 12-15-2013, 07:50 PM
lookin4myPSD's Avatar
Use an air wrench and just zip zip zip a few times and it should loosen up. That's all I know about turbos! Haha
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #8 of 19 Old 12-16-2013, 01:15 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Uh no... definitely do not do that.
Removing the turbo is easy... 4 bolts on the pedestal, then unclamp the up pipe and downpipe, oh and remove the intake spider which is just more clamps and boots.
post #9 of 19 Old 12-16-2013, 01:23 PM
No? I couldve sworn I heard it somewhere on here That you do that to remove the wheel. Oh well, now I am informed.
Early 99 F250 ECLB,
post #10 of 19 Old 12-16-2013, 03:32 PM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
LOTS of people have done this without Any trouble (including Me )
NoRalPh is offline
Tags
compressor wheel , filter , turbo
