99 7.3 problems - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-10-2013, 05:30 PM Thread Starter
99 7.3 problems
hey guys I got a 99 7.3 powerstroke with a straight pipe and a ts 6 position. the problem is some times it will run fine then other times its slow and has no acceleration. sometimes under wot it will run like a raped ape then will lose power. then sometimes will just off after a blip of the throttle and wont restart for awhile. changed icp senor bout a month ago and cps yesterday didn't help at all. any help welcomed!
strokin 6.0 05 is offline
post #2 of 3 Old 12-14-2013, 06:02 PM
lookin4myPSD's Avatar
Erm...my suggestion would be with the IPR (Injection pressure regulator), if it gets stuck or somehow allows the incorrect pressure, it may kill the power. And, if it has some sort of correlation to the fuel level, the problem may be in fuel delivery. I say IPR though because I had a similar problem.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #3 of 3 Old 12-14-2013, 07:01 PM
Quoted: 759 Post(s)
I agree, possibly hpop itself or possibly fuel pump has intermittent hiccups.
Corey@CNCFAB is offline
