Leaking injector O-rings - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-10-2013, 09:23 AM Thread Starter
Is it possible to have a leaking injector O-ring that would allow oil to leak out of the exhaust and CCV mod? Truck runs fine just the leaking oil with no fault codes
fomoco is offline
post #2 of 3 Old 12-12-2013, 01:39 PM
Have you checked your turbo to verify that it is not leaking?
2000 F350 4X4 CCSB w/ 7.3 and 4R100
PIS 175/80, Adrenaline HPOP, 4" Exhaust, 6637 Filter, CCV Mod, Leveled Front, 315/75/16 Goodyear Duratracs
Devil Car is offline
post #3 of 3 Old 12-12-2013, 04:26 PM
lookin4myPSD's Avatar
In my semi-amateur opinion, the answer to the OP's question is a simple no. If you had oil leaking from the injector into the cylinder (somehow), then you would probably be balls deep in hydrolock and not like life very much. As for the CCV mod, the oil come out of the injector in the valve train, but is spit into a deflector and directed downward back into the crankcase.
So...unless a deflector is missing and spitting oil everywhere and into your ccv, then, I don't think the first question is possible.
and. regarding the oil leak, definitely look into the turbo. The exhaust oil leak is a red flag, the ccv tends to drip oil anyway. Good luck, hope you find a solution!
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
