Huge OIL leak from exhaust - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-09-2013, 05:29 PM Thread Starter
I have oil leaking from the turbo EBPV pedestal rod, which is bad but can fixed with a NON EBPV base. My BIG problem is oil leaking from my CCV mod and exhaust bad???? but not all the time WHY? The oil leaking from the EBPV rod is bad but I cant understand how to find out where the oil is coming from that's getting into the exhaust and the CCV mod that is ran to the back of my truck, I checked the turbo for end play or any movement but it's all good, please tell me it's not catastrophic engine failure. it only smokes when you let of the throttle and the there is the constant cycling of the EBPV WTH! sorry I posted this in the wrong section just a few min ago.
fomoco is offline
post #2 of 3 Old 12-14-2013, 04:25 PM
lookin4myPSD's Avatar
If you're tired of the EBPV cycling, just pull the plug on it. Can't tell you much about the oil in exhaust, but the ebpv will stop cycling if you pull the plug on it. It just won't warm up as fast.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #3 of 3 Old 12-26-2013, 12:37 PM Thread Starter
update to oil leak
Thanks for the info, I found out what the problem was, the EBPV rod is leaking from the piston rod when cycling. So with some help from Bob @ diesel O-ring I was able to fix the leaking issues. I did unplug the EBPV and was able to drive my truck until the parts come in. I assume the oil leak in the exhaust is from a connection in the up-pipes!!!??? I will look for it when I get the parts. Also I did the oil cap blocked CCV test and happy to say no issues.
fomoco is offline
