EBPV control? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-07-2013, 09:09 PM Thread Starter
DieselGod's Avatar
Send a message via Skype™ to DieselGod
EBPV control?
What all tells the EBPV to close in cold weather? I thought it was the intake air temp but I have also been told its the engine oil temp...I would really like clarification on this because it was 2 techs at 2 dealers that gave me the 2 different stories! Another guy said it is tied into the exhaust back pressure sensor too...not even 100% sure what that sensor does either lol
Thanks!!!
2000 F-350 Lariat Dually 7.3 PSD
Custom built tranny, B&W +3 qt pan,BD cooler w fan
Custom painted 1 off 430 litre slip tank
Custom built electric re-fuel on the fly system (Me)
TDS stock rate Injectors
TS chip by Tyrant Diesel (nice tunes Cale!)
Banks Technicooler
Snow Stage 2 meth/water injection
BD Thruster II turbo(non-California)
4" turbo Back straight pipe Exhaust w 6"MBRP tip
AFE Stage 2 Intake & Zoodad
BD Exhaust Brake
AMSOIL bypass filter
Coolant filter (me)
DieselGod is offline
post #2 of 4 Old 12-08-2013, 08:30 AM
lookin4myPSD's Avatar
The Exhaust back pressure valve is actuated by the PCM, but the parameters monitored to actuate it are definitely from the EBP sensor, and...either EOT or IAT, I would guess.
All the sensor does is senses the Exhaust back pressure from a small tube that runs from the exhaust to the front of the engine. Its only purpose is to close the valve. If it's unplugged, then the valve wont do anything. I've had mine unplugged for months. No problems.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
The Following User Says Thank You to lookin4myPSD For This Useful Post:
DieselGod (12-08-2013)
post #3 of 4 Old 12-08-2013, 09:50 PM Thread Starter
DieselGod's Avatar
Thanks! I suspect IAT is likely...it's so cold that with the performance Intercooler and AFE stage2 my IAT was showing -16 degrees! I came up with a mod for the heat shield I hope will draw in warm air from the engine bay...
Banks Technicooler
BD Exhaust Brake
Coolant filter (me)
post #4 of 4 Old 12-13-2013, 09:18 PM
-16 degrees? Wow. I'm sort of oblivious to this cold weather all around me, living in Florida. It's been 80's here non-stop. I can't stand it. Either way, best of luck to you and your hopefully fruitful efforts!
Early 99 F250 ECLB,
