Truck randomly blows white/grey smoke - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-07-2013, 06:47 PM Thread Starter
This problem started where some days I would drive my truck all day and it wouldn't blow any smoke. Other days it would smoke all day. When i say smoke its only at idle and on take off. (IDLE) Sometimes the smoke at idle is just a constant puff others its so bad at times the truck is in a thick cloud. (TAKE OFF) When the truck is smoking the amount of smoke at take off it pretty consistent. It blows so much that the I can't even see the car behind me. Not while driving down the road. Now it pretty much smokes every day. But I can be driving the truck all morning smoking and sometime during the day it will stop smoking. I don't do anything different. The problem is not consistent at all.
Sometimes it will smoke at a stop sign, I will take off and smoke horribly, then drive down the road 10 miles and stop again and no smoke at idle or take off. Sometimes it will smoke at a red light i will drive 1/4 mile to next red light and no smoke, start and stop 20 more times no smoke then stop the 21st time and it will start smoking again. Sometimes it will smoke and stop smoking randomly and not smoke anymore that day.
Video of my blow by. Its not to bad for 260k miles.
20131125_151105_zps841c0f47.mp4 Video by pilcherdustin | Photobucket
dustys7.3psd is offline
post #2 of 2 Old 12-08-2013, 07:34 AM
lookin4myPSD's Avatar
Do you know the condition of the injector o-rings? Might be time for a new set.
Also check the turbo compressor for any sort of excessive play. a little is fine, but not much.
I had an intermittent smoke problem, too. It went away after I replaced the injector o-rings (they were falling apart as I pulled the injectors). But it was white/grey smoke just like you said.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
