Slow spool - Ford Powerstroke Diesel Forum
post #1 of 13 Old 11-11-2006, 07:03 PM Thread Starter
lawman349's Avatar
Slow spool
I seem to have some acceleration issues.
As I accelerate, I notice the turbo doesnt really spool up until i hit 2000-2200 rpm. that seems kinda sluggish to me. i hear guys talk about how their trucks will spin the tires off...mine wont even chirp. when the turbo does spool up, the truck takes off like a scalded cat. what is the normal RPM in a early 99 7.3 where the turbo really spools up?
does anyone have any ideas? i am thinking of replacing the intercooler boots as they has alot of crud on them. i am assuming they are leaky. I am sure this is at least contributing to my problem...i am assuming they are stock, but i have only had the truck since August.
I have also had some minor trouble with that dang EBPV. It was opening and closing at highway speed. doesnt seem to be doing it now, though.
...or could the wastegate not be closing all the way?
what do you guys think?
(no gauges yet. the chief financial officer (wife) has not yet approved the request.) LOL
lawman349 is offline
post #2 of 13 Old 11-11-2006, 07:12 PM Thread Starter
lawman349's Avatar
i guess i should gave told you guys the truck specs,,,i just completed the sig...here it is:
Early 99 (02/98) 7.3L, Supercab, 4x4, 4" ProComp Lift, 35" Cooper Discoverer Tires on American Racing Atlas wheels. 4" exhaust w/ 5" tip. 129K and counting.
2003 F350 SRW CC 4x4 6.0L
Coolant Bypass Filter w/ Cat ELC
Amsoil Oil Bypass Filter
Hypertech MaxEnergy / Bully Dog Outlook
Cat and muffler DELETE!
Icon 2" leveling kit
Mickey Thompson MTZs
ARP Head Studs / New Ford OEM HGs
New heads
Sinister Diesel EGR Cooler
Blue Spring Upgrade
New HPOP STC connection
post #3 of 13 Old 11-11-2006, 07:35 PM
cummins_power's Avatar
sounds like it could be a fuel problem lawman. do you have a fuel pressure gauge? what kind of pressure you gettin??
cummins_power is offline
post #4 of 13 Old 11-11-2006, 07:50 PM Thread Starter
lawman349's Avatar
you know, c_p, you may be right. i dont have a fuel pressure guage, but i bought the truck used in Aug and i'd bet the fuel filter is shot...
New heads
Blue Spring Upgrade
post #5 of 13 Old 11-11-2006, 07:53 PM
not only that if your not pushin enough fuel you wont make enough exaust and your turbo will spool real slow. but yeah i would definantly change that fuel filter and if that dont fix it get a fuel pressure gauge or take it to a mechanic so he can put his gauge on it. what kind of egt's you gettin?
hope the filters all it is tho.
post #6 of 13 Old 11-11-2006, 08:10 PM Thread Starter
lawman349's Avatar
i dont know about the EGTs...i dont have gauges yet. That is next on the list before i get the Bully Dog tuner.
New heads
Blue Spring Upgrade
post #7 of 13 Old 11-11-2006, 08:11 PM
definantly a good investment. hope you figure everything out
post #8 of 13 Old 11-11-2006, 09:55 PM
Powerstroke Techie
djsdiesel's Avatar
What intake is on it. The stock early 99 air box is a piece of $#!+. The tabs break and allow dirt to enter unfiltered, also it sucks air from the inner fenderwell, so in the rain the filter looks like wet toilet paper and air won't flow through to well. Also if it has the original airbox I'd look at the turbo impeller to see if it looks damaged.
But on the otherhand on a stock truck with lift and big tires you'll have to powerbrake it pretty good to break em loose.
99.5 F-250 PSD AT 4x4, 4in lift, 37 13.5 18 Pro comp Extreme A/T's, S&B Intake, GTP38R, DP Tuner custom programs (140 Agg., 120 sled pull, 80 tow and 60 tow), Rosewood DIY stage 2 injectors, BTS Trans, 5in exhaust no muffler, 6 oh intercooler, Ford AIC, EBPV delete, Foil delete, T/C lock up mod, Pusher Fuel Pump, Three Chime train Horns
djsdiesel is offline
post #9 of 13 Old 11-12-2006, 12:08 AM
99Smokin73Stroker's Avatar
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
So basically your truck is stock other than the exhaust and lift/tires? When I put my old early 99 on stock it wouldn't do much of anything other than run like a turtle.....basically everything you described.
2005 F350 XLT FX4. 2.5" leveling kit, 03 turbo, 4" MBRP Turbo-back, 58v FICM, SCT X4, Irate Diesel coolant filter
99Smokin73Stroker is offline
post #10 of 13 Old 11-12-2006, 02:29 AM
tstroke's Avatar
power adder
i just bought a sniper interface and it is like day and night and the tires bust to easy vary happy with it
tstroke is offline
