long cranking to start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-05-2013, 01:59 AM Thread Starter
EZB
i have 02 7.3 just replaced glow plugs,turbo, injectors. i takes 10 sec to start i was leaking oil into fuel before the repair. could there be to much oil in the fuel to cause this?
EZB is offline
post #2 of 3 Old 12-05-2013, 07:59 PM
lookin4myPSD's Avatar
If you were leaking oil into your fuel rail (I'm guessing due to bad injector o-rings), then it shouldn't take long at all for it to be cleared out. Driving it rather aggressively for a little while would probably clear the oil out of there.
Is the long cranking only when it's cold, or all the time?
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #3 of 3 Old 12-06-2013, 08:45 AM Thread Starter
EZB
ITS GETTING BETTER I JUST WANT TO MAKE SURE I DIDNT FORGET TO DO SOMETHING. THANKS
EZB is offline
