engine code p1247 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-26-2008, 12:22 PM Thread Starter
engine code p1247
Just got the p1247 low boost pressure code
Truck seems to be running fine.
Just installed a 5" exhaust and Hypertech power 3 which is when i noticed the code. Reset codes to install.
Ive been told there are many reasons that this can happen, does anybody have more information for me than the tech at FORD?
tollboothwilley is offline
post #2 of 6 Old 08-28-2008, 09:41 AM Thread Starter
anybody there?
post #3 of 6 Old 08-28-2008, 09:50 AM
southern7.3's Avatar
someone will be along in a bit with some info for you. I believe mine threw the same code but it was b/c i had unplugged the map sensor. Check out your downpipe from your turbo since you installed a 5" kit
BTW get you some gauges if you dont already have em, boost, pyro, and tranny
Sam
2005 F350 King Ranch CC DRW Insight Leveled 4" MBRP Straight Pipe Tinted
'99 F250 - Sold
'99 Cummins - Sold
southern7.3 is offline
post #4 of 6 Old 09-08-2008, 12:56 PM Thread Starter
in the process of the gauges...
if there was a leak in the downpipe, wouldn't i be able to hear it?
post #5 of 6 Old 09-08-2008, 04:27 PM
Cynic
Dirk's Avatar
Lots of reasons. You need to check the gaskets on the uppipes to the turbo. Any soot on the firewall around them = bad.
Remove the EBP sensor and clean it out. Remove the EBP tube, clean it out.
Clear codes. Drive around. Rescan.
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
post #6 of 6 Old 11-21-2010, 01:24 PM
gsxrboi1430's Avatar
Check your intake and your turbo.... i had that code because my turbo was hanging on with one bolt because the guys at the exhaust shop SREWED UP... I'm not saying your turbo is hanging off but... check all your forced air induction routes...
2002 F350-DRW CC 4X4 (POLAR BEAR)
AIRAID INTAKE
FOIL DELETE
ZOODAD MOD
AIR DOG 100
200cc Single Shot INJECTORS
EDGE EVO2 for gauges with DP TUNER
ARP Studded
SUNCOAST 4R100
BIG BADD WOOF TURBO
4" BANKS MONSTER EXHAUST (no muff) 5" Tip
C&D TRANSPORTATION powered by
gsxrboi1430 is offline
