EBPV Problems. - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-02-2013, 06:22 PM Thread Starter
EBPV Problems.
Hi there, im new to the diesel world and its still a learning procces so please bare with me. I bought the truck last march while it was still fairly chilly 30s and 40s i dont ever remeber the ebpv closing nor the high idle kicking on. this past couple weeks it has been in the high 20s low 30s and the past 2 days the ebpv decided to start closing and opening it hasnt worked at all yet this year besides the past couple days. and still no high idle when i fire it up. After some reading i unplugged the regulator at the turbo pedastal but now it seems like the valve is still partially stuck closed. there is no hissing noise but the exhaust does not sound normal and the truck is sluggish. Is there anyway to know for sure that the valve is all the way open besides pulling everything apart to look and what would cause this to happen along with no high idle? on a side note my fuel milage is averaging 10-12 mpg normal driving. any help would be much appreciated. Thank you.
00 F250 7.3l 6 speed , hutch mod, Coolant Filter, 203* Thermostat, Afe Big Boost 6637 Filter, 4 inch turbo back straight pipe, garret non ebpv pedastel, garret highflow out let, riffraff Billet compressor wheel.
firefighter33 is offline
post #2 of 9 Old 12-02-2013, 06:25 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Why did you unplug it, the EBPV doesnt kick in right on start up, when you let it run for 2-3 mins then the high idle will kick on. plug it back in and see if it kicks on?
2000-7.3L is offline
post #3 of 9 Old 12-02-2013, 06:36 PM Thread Starter
I unplugged it because i was tired of my truck sounding like a jet everywhere i went. I drove it for almost 4 hours straight yesterday and the whole 4 hours the valve was opening and closing. I start my truck up and let it run for 5-10 minuets every morning. The ebrake light comes on but no high idle. I dont ever remember the ebpv working last winter and its been cold for a month or so now. why would it start doing it now. ive driving it on days in the teens and the valve didnt close.
post #4 of 9 Old 12-02-2013, 06:37 PM
2000-7.3L's Avatar
sounds like a stuck valve....pull the pedestal out and clean it up or delete it!
post #5 of 9 Old 12-02-2013, 06:43 PM Thread Starter
im gonna be upgrading in the summer. just trying to stick it untill then. Will it hurt anyting if i just turn the valve open? i assume from what i read that it is supposed to spring open when the regulator is unplugged. but im pretty sure its not open all the way and would this be related to something that controls the high idle?
post #6 of 9 Old 12-02-2013, 06:45 PM
2000-7.3L's Avatar
if you keep it the way it is it will be sackless and you will loose MPG but you can pull it and clean it, throw it back in and G2G(good 2 go)
post #7 of 9 Old 12-02-2013, 06:49 PM Thread Starter
yeah thats what its doing now. it has had bad mpgs and sluggish since i got it in february. maybe it has always been stuck and finally is starting to break free. i have no idea. that will be a week end project. but as far as the high idle problem any clue?
post #8 of 9 Old 12-02-2013, 06:51 PM
2000-7.3L's Avatar
Yes if its stuck and clogged with chit then it wont cause the high idle to kick, once its cleaned up it should kick on start up!
Sent from AutoGuide.com App
post #9 of 9 Old 12-02-2013, 06:58 PM Thread Starter
that makes sense. ill have to give it a good cleaning see how it goes. thanks for the help i really appreciate it.
