7.3 problems help please - Ford Powerstroke Diesel Forum
post #1 of 15 Old 12-01-2013, 03:24 PM Thread Starter
Ok so I'm new to the form. I have a 1999 7.3 f350 2wd drw I just installed a reman engine iv got about 400 miles on it I live in VA been kinda cold snore iv done this so my questions are it takes it a little while to start up in the mornings when cold and never starts rite up as it should I don't think. Has lots of white smoke when cold . Has a p0541 code for intake heater then every once in awhile the cel will flash on for a sec and go away it pops a p1316 and a p1670 code if anyone can help me out it be great .. oh and I noticed the other night I was sitting at the store talking to a buddy and left truck running and reved it up a Little bit to let him hear it and it puffed out some white smoke but has to idea for awhile . I'm thinking maybe a leaking or sticking injector but truck runs great so any help be awesome
rustyg23 is offline
post #2 of 15 Old 12-01-2013, 03:38 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
First thing you want to do is to check-out the entire Glow Plug System (plugs/relay/connections). Have a look here -> Troubleshooting GPR & GP's
If you plug it in for a few hours, on a cold morning when you'd expect it to give you trouble, and it starts normally, it's a good indication something's lacking in the GPs.
The 541 I wouldn't worry about, the AIH is pretty useless and not part of your problem.
The 1316 is the IDM telling you to perform a Buzz Test to allow it to further resolve specific codes that should help you narrow it down (what are you using to scan?)
The 1670 is also part of an IDM issue, something's going on there, you want to maybe look into the UVCH plugs. Did you use new Valve Cover gaskets with those connections? They are important for Both the GPs & Injectors...
NoRalPh is offline
post #3 of 15 Old 12-01-2013, 03:45 PM Thread Starter
OK I did use new glow plugs ..I used my blue point scanner I'm going to use my good one tomorrow when I get to the shop. I did not use new vs gaskets they are the newer ones from the Ford recall I do believe tho I put new o rings on the injectors I found that 7 of them looked new and one of them had the stock o rings but like I said runs to good to have a full blown bad one . You think that just a wire issue or something ? I noticed it threw the cel on a few times going up a step hill on the gas pedal a little more then normal to keep up the speed
rustyg23 is offline
post #4 of 15 Old 12-01-2013, 03:48 PM Thread Starter
I haven't tired plugging it in yet will do that tomorrow if it's cold.
rustyg23 is offline
post #5 of 15 Old 12-02-2013, 06:02 AM
Quoted: 157 Post(s)
Fine out what the CEL is all about and do a Buzz when you get it there.
The VC gaskets are the electrical connections and prone to failing, especially as they loosen and Arc. It's always good idea to look them over carefully when you have them in your hand
NoRalPh is offline
post #6 of 15 Old 12-02-2013, 06:08 AM Thread Starter
OK will do . But if the wiring was bad wouldn't it run bad or throw the codes constantly?
rustyg23 is offline
post #7 of 15 Old 12-02-2013, 06:34 AM
Quoted: 157 Post(s)
Maybe not,,, that's the nature of failing connections sometimes.
NoRalPh is offline
post #8 of 15 Old 12-02-2013, 06:43 AM Thread Starter
Yes ture . I have another truck it's a late 99 f550 would the idm be the same on it I could try changing it out if we think that needs to be done from what I can Remember the vcg looked really good and arnt that old I'm bout to try and do a buzz test
rustyg23 is offline
post #9 of 15 Old 12-02-2013, 07:41 AM
Quoted: 157 Post(s)
AFAIK - Any 7.3 IDM will work...
NoRalPh is offline
post #10 of 15 Old 12-02-2013, 07:44 AM Thread Starter
OK so I hooked up my good scanner I got p1274 I think it said it was high low voltage in number 4 when I done the buzz test .
rustyg23 is offline
