01 SD no oil pressure - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-30-2013, 09:57 AM Thread Starter
Exclamation 01 SD no oil pressure
Truck had a oil leak we found oil cooler was leaking. We replaced o-rings and gaskets on cooler. After restarting truck we have no oil pressure. Only way to get truck running is to fill the HPOP reservoir. It will run until its empty but the oil pressure never comes up. Thanks
aatjohn is offline
post #2 of 3 Old 11-30-2013, 11:30 AM
remove oil filter and make sure the fiber washer that is held in by a small snap ring is sealed tight if lose the hpop will drain from that. did u take anything else apart on the cooler if not should not have any problems with oil pressure.
20007.3l is offline
post #3 of 3 Old 11-30-2013, 12:57 PM Thread Starter
The fiber washer looks good. All we did was take the ends off the cooler and replace the o-rings. We drove it into the shop for the oil leak.
aatjohn is offline
