Anyone?
I Have A 2000 Excursion With 59k Miles. In The Morning When You
Start It The Motor Revs Up A Little About Three Times Then Runs Smooth. Is There A Reason For This? The Only Time It Does This Is In The Morning. |
how many miles you got on the oil?? that would be the first place i would start......could be a glitch in a sensor or other things as well. Any codes??
Oil
It Has 200 Miles On Oil Change? Codes?
when did it start, can you relate it to anything that was done to the truck??
No
It Is 100% Stock.
Hi,
I have the same thing happen with my '02 f-550 /7.3 My dealer says it the cold weather feature /IDLE UP If left alone , the computer will close the exhaust gate valve at the turbo Raises RPM to build a little heat in the motor . By touching the brake pedal ,clutch or releasing the parking brake lever returns back to idle and the timer starts again til the coolant reach |
