7.3 Broken lifter - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-29-2013, 05:50 PM Thread Starter
rp3
7.3 Broken lifter
I bought a 2001 F-250 that has excessive white smoke after warm up. It gets worse the longer it runs. Thinking it was an injector or O-rings I took the valve cover off to repair it. Cylinder 1 failed the contribution test. Well what I found was not what I thought was wrong. the intake valve was not opening. I could stick my finger between the push rod and rocker arm. Figuring it had wiped out the cam. I checked the cam lift for laughs and it cam out at .2535 in. Right on the money. So I tore the head off the right side to see what was up. What I found was not something that I am used to seeing. ( I work on heavy trucks ie. ISL, ISM, ISX, MP7 and E-Tech engines). The bottom 1/4 of the lifter is broke off. Roller pin and 1/4 of the body are gone. The camshaft lobe though is in great shape, no damage from what I can see.
So it seems the parts have fallen into the oil pan and I am going to drain the oil tomorrow and see what I find. Has anyone seen this before as I thought 7.3 lifters are not much of a issue in these engines. Would you fish out what you can and install a new lifter and let it go? this is going to be my truck so if anything happened it would be on my dime... Thoughts?
rp3 is offline
post #2 of 3 Old 11-29-2013, 06:37 PM
Powerstroke Techie
You want a neat piece of information?
SBI International Hydraulic Valve Lifters | Northern Auto Parts
have a look at the interchange info. These lifters fit EVERYTHING.
At this point, if it was mine, I'd pull the motor and drop the pan and make sure there isn't a bunch of lifter parts in it. It would likely save you money down the road.
Odds are if you live in the rust belt it could use a pan anyhow LOL.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 3 Old 11-30-2013, 02:56 AM Thread Starter
rp3
Yes , if it was a customers truck I would be pulling the engine. I would not gamble with someone else's money. If something happens its on me, so not as inclined to pull the motor but on the other hand I could give myself a pretty big bill of it tears up the engine. Choices choices.
rp3 is offline
