Won't start/ only runs when in 'start' position - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-29-2013, 04:46 PM Thread Starter
usteffenhagen's Avatar
Hey ya'll
I come bearing another issue...
Earlier it was about 35*F and I tried starting. Heater wasn't plugged in either. Usually it starts fine, maybe a little rough. But anyway, I cranked for about 4-5 seconds Nothing just smoke. I tried again and it was trying to turn over and finally did but i had to continue with the key in the start position so the starter was basically keeping the engine running, also it ran like complete crap obviously. So my question is.....CPS?? I kinda thought GPR but that doesn't sound likely because it did in fact try to start. I got the heater plugged in tonight and I'll try her again in the morning just to try and isolate the issue further. I should also throw in the fact that when it did crank, it wasn't slow or anything, sounded like normal. My volt idiot gauge did drop down to about 8-10 thought but it definitely had the cranking amps.
Thank's in advance guys!
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 9 Old 11-29-2013, 08:13 PM Thread Starter
Just a thought, would it be possible my ICP could give me this problem? It does have oil in the sensor....
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #3 of 9 Old 11-30-2013, 04:39 AM Thread Starter
Anyone have any ideas??
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #4 of 9 Old 11-30-2013, 05:22 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
I would test the gp and gpr. From what i have read the icp is bad if it has oil in it, unplug it and it should go into a factory preset mode.
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #5 of 9 Old 11-30-2013, 05:25 AM Thread Starter
If I unplug it, shouldn't it throw a code?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 9 Old 11-30-2013, 06:23 AM
Quoted: 157 Post(s)
Unplugging it Will throw a code because the PCM doesn't see any reading from it. It then substitutes a default pressure for the IPR to use (limp mode).
BUT, all the oil in the connector tells you is the internal seal on the ICP might be failing. It doesn't mean the ICP isn't still functioning just fine.
Do you now have an SES light (before trying to unplug it) ? Your problem doesn't make me think of ICP first though, could be of course, but there more likely causes first. Codes might help now...
See if plugging-in cures it, if so the whole Glow Plug system (plugs/relay/connections) are most likely the problem.
Also, on a side note, if you actually hit 8v (depending on the PCMs programming, and an '01 might go either way) it may not start based on that alone. The PCM has certain criteria it needs to see and too low voltage can cause it Not to trigger the IDM to fire the injectors.
NoRalPh is offline
post #7 of 9 Old 11-30-2013, 07:36 AM Thread Starter
Ok thanks for the good insight. I didn't unplug the ICP but it did start after the block heater was plugged in and it started right up. how can I test my GPR/ plugs?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #8 of 9 Old 11-30-2013, 07:50 AM
Quoted: 157 Post(s)
All spelled out nicely here -> Troubleshooting GPR & GP's
NoRalPh is offline
post #9 of 9 Old 11-30-2013, 08:24 AM Thread Starter
Good deal thanks
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
