Won't start occasionally then died on road - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-28-2013, 08:24 PM Thread Starter
So for the first time since I've had the truck, I went to start it an all it would do is crank. Added a little oil since it showed low and it fired right up. Drive it for a while, killed it and started back up. I figured that was the end of my problems. Later, I went to start it and it would crank, but no start. Added a little more oil, no help. Waited about 10 minutes, fired right up. Drove it parked it started again, maybe just a fluke? Well after that, driving down a dirt road all of a sudden dies. Crank but no start. Got it pulled home 15 minutes later started. Drove about 7 miles down the highway, died again. Already replaced cam position sensor. What else could it be?
Thanks
MichaelM is offline
post #2 of 7 Old 11-30-2013, 07:48 AM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
That CPS would be the first choice, next is more info on your truck maybe... What yr is it? Is the SES light on or been on?
What do you mean by "a little oil"? How low was it? Did it drop between having to add more a second time? After it dies I would look into the HPOP reservoir (little plug in the top) and "dip" it to see if it's not empty or very low.
Take a look at the IPR maybe, make sure the tin nut hasn't fallen off and the plug & wiring look OK (the insulation can crack & fall-off). It's the next Heat Related sensor failure I think of (if this is heat related).
NoRalPh is offline
post #3 of 7 Old 12-03-2013, 04:47 PM Thread Starter
It's a 2002, all that is done to it is a ts 6 position. The oil had dropped some due to the oil cooler leaking when it was cold. At first, it had dropped maybe a quart under the add mark. No ses light, no codes or anything. The ipr is fine, and idk about the rest, I will have to check. Thanks man
MichaelM is offline
post #4 of 7 Old 12-05-2013, 09:04 PM
lookin4myPSD's Avatar
I had been chasing this same problem for three months. I can't give you a definitive answer, but when I replaced the CPS, IPR and injector O-rings, the problem went away.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #5 of 7 Old 12-05-2013, 09:09 PM Thread Starter
I had heard that IPR might be causing it, and then from a friend who's a mechanic that he's seen it in the injector o rings. IPR is what I'm about to try
MichaelM is offline
post #6 of 7 Old 12-05-2013, 10:07 PM
The o-rings are definitely the cheaper of the two items. Cost me about $65 for the o-rings, and $150 for the IPR. I did the o-rings in an afternoon. I have 205k on my rig and the orings came out in pieces. MAKE SURE TO look in the injector cups with a flashlight for debris. I had to pick pieces of oring out of mine.
Trust me though, having the right tools makes so much difference. A nice pry-bar, and some dental picks make a world of difference.
Early 99 F250 ECLB,
post #7 of 7 Old 12-06-2013, 06:15 AM Thread Starter
Thanks man, I already have an IPR being shipped to me. So I guess if that's not it at least I have a new one there anyway lol
MichaelM is offline
