Injector Question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-28-2013, 02:55 PM Thread Starter
Injector Question
My nephew just picked up a 2000 F350 PSD for a really good price. He bought it knowing there were at least two bad injectors (hence the really good price). His buddy has a stock '95 7.3L he said he could have for parts. Will the injectors from a '95 fit a '00? Are there any other issues to be aware of?
lmorgan is offline
post #2 of 2 Old 12-05-2013, 08:12 PM
lookin4myPSD's Avatar
Injectors from a '95 will NOT fit the '00 PSD. They will fit in the same hole, but don't do it.
Stock injectors from a 95 PSD are single shot injectors, and the '00 has split-shots. Using both simultaneously would result in a very rough running engine. So...don't do it. Pick up some remanufactured injectors. They run about $175-ish a piece.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
