7.3 coolant temp sensor - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-27-2013, 10:35 AM Thread Starter
If it aint a CAT itsa DOG
dieseldan2005's Avatar
I have another question for you guys on my new to me 2000 7.3 When i hooked up my AE to it, the coolant temp will just keep climbing on the computer up to 300 some degrees. This happens even when the engine is just started. The EOT seems normal. I was checking these because my cooling fan loves to keep cycling on and off, more staying on. Again right from a cold startup. This is with all the HVAC controls off, so defrost wouldn't be calling for ac. Does it sound like i have a bad coolant temp sensor or EOT sensor? The 2 problems have to be related some how.
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #2 of 9 Old 11-27-2013, 10:56 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
7.3 doesn't have a coolant temp sensor that the PCM can see. The sensor just is hard wired to the gauge in the dash. I'm pretty sure the PCM uses a mix of the intake temp sensor and the EOT sensor. Some one can correct me on that though. What do those sensors say when you hook it up?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 9 Old 11-27-2013, 11:07 AM Thread Starter
I didn;t check the intake temp, but the oil temp was reading correctly, starting out low and slowly climbing when the engine is cold. When i tried it with the engine warm it was reading normal oil temps, but the coolant was in the 300's which is obviously way off.
Diesel Dan
post #4 of 9 Old 11-27-2013, 11:18 AM
Chapter Director
Quoted: 5 Post(s)
Maybe see what that says those are the only 2 things that I believe could influence the fan
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 9 Old 11-27-2013, 12:10 PM
Quoted: 174 Post(s)
Feedback Score: 3 reviews
From the, now defunct, AE Forums;
"I wrote to AE support about this issue. They confirmed that the pinout is there and AE sees it but the 7.3 application does not use this pinout so it floats - the result is that we see bogus information. Just ignore it, it's a result of Ford using the same hardware for multiple applications.
So now we have our answer - just ignore this information. Wish I had known this before - I momentarily panicked when I saw my coolant temp at 280F"
NoRalPh is offline
post #6 of 9 Old 11-27-2013, 12:28 PM
Chapter Director
Quoted: 5 Post(s)
So is that saying the 7.3 can see coolant temp or is just the pin out there but not being used? I have always thought the PCM couldn't see ECT until late 01 when they did the big electric switch over
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 9 Old 11-27-2013, 01:30 PM Thread Starter
That is interesting stuff. So back to my other problem, what else would cause my fan clutch to keep kicking on when there is no demand for it?
Diesel Dan
post #8 of 9 Old 11-28-2013, 06:22 AM
Quoted: 174 Post(s)
I've never been sure...
There's talk of transmissions effecting the system monitoring the ECT (manuals -vs-auto), the cluster is the only thing connected to it, and what I took from the AE Forum above. I wasn't a participant, just wondered why I saw coolant temps I couldn't account for and looked it up there.
They, and here I'm not sure who "they" were, came back with the whole "pin-out" answer but, again, I've never really understood it either
To the OP, the fan clutch has no idea of what any sensors are seeing. It's self activated...
NoRalPh is offline
post #9 of 9 Old 11-28-2013, 08:34 AM
Chapter Director
Quoted: 5 Post(s)
Well ill tell you when i monitor with my torque app my coolant shows as -30 degrees so im sure its the same sort of deal as AE. The way i interpret the pin out being on the PCM is just like how when you plug a L99+ pcm into a E99 truck all of a sudden they get a cruise control light that they didnt have before.
I feel its something they always wanted to incorporate but never actually got it to work until L01. An interesting test would be putting a pre-L01 PCM into a L01+ truck and see if you can get some readings for coolant
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
