19* cold start= a qt of oil on ground? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-26-2013, 01:47 PM Thread Starter
Carolina444's Avatar
Went out to warm up truck(19* outside) noticed that it ran rougher than usual this cold. I jumped out and for some reason i looked behind me and saw a quart or more of oil pouring out from bottom of truck..WTF!! Didnt have time to really look at it but it looks like it is coming from above or around oil cooler and running down front end and oil filter. top side(valley) of engine looks dry. What could cause this much oil to leak in that short of time? thanks
Early 99 f250 cclb,244k, ccv, Tymar intake, 4" diamond eye, 5" tip, 140v IDM, php hydra, isspro's, riffraff boots & billet wheel, ebpv delete w/ high flow outlet.
P.I.S injectors coming soon
Carolina444 is offline
post #2 of 5 Old 11-26-2013, 01:53 PM
schlutzer's Avatar
Quoted: 18 Post(s)
it's probably the seals on the oil cooler... I did mine last year.
They tend to go in the winter time.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 5 Old 11-26-2013, 06:11 PM Thread Starter
Just ordered a oil cooler oring kit and hpop
Kit.. To me it seems like it would be a hpop with that amout
Of oil lost that fast.. Also it was running real
Rough..
post #4 of 5 Old 11-26-2013, 06:21 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Low oil can = Rough running and hard starts. Mine even 1 litre low causes a miss.
if it was your HPOP you would have oil all over the top of the engine, and your truck wouldn't run.
A big oil leak like that would be very easy to find... you said oil cooler area so that's what I suggested, it's one of the most common oil leaks.
post #5 of 5 Old 11-26-2013, 06:36 PM Thread Starter
From the quick look i took it looked like the cooler and the top side of motor was dry.. I hope to have a chance this weekend to take a better look.. Thanks
