Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
  #11 (permalink)
Old 08-25-2008, 04:52 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
the cups will hairline crack and i dont think a standard cooling system presure test will show the leak if it is a cup, the crack will swell with heat , with that mileage i still think its possible to have a decavitation situation here as well
  #12 (permalink)
Old 08-25-2008, 11:22 AM
cfunderb cfunderb is offline
I've had my oil cooler rust out before. The coolant disappeared into the oil, not the other way around. I just kept adding coolant over and over (slowly). So I don't think it's your oil cooler. What's interesting is that there is oil in your cylinders.
  #13 (permalink)
Old 09-14-2008, 12:17 PM
spanky86 spanky86 is offline
Sorry its been so long working out of town alot. scuffy what do u mean decavitation. i also finally had time to drain the oil pan and a lot of coolant came out.
  #14 (permalink)
Old 11-10-2008, 03:59 PM
found out what a decavitation issue is and want to find out what might go out if that is the problem(prevoius owner and i did nothing about it we didnt know about it). talked to mechanic and he told me that all the cylinders are pushing water and #7 have a major issue probably needs a new problem
