Blue smoke on cold start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-21-2013, 07:27 AM Thread Starter
usteffenhagen's Avatar
This morning it was about 38*F outside, waited for the WTS light to shut off and started it. It was quick as usual to turn over but when it did it let out a decent puff of blue smoke and had a small flow of smoke puff out of the pipe for a minute. I've read a few different things:
1. injector(s) going out
2. Glow plugs
3. Unburned fuel
I'm leaning towards unburned fuel because it'd not constant and last week when it was below 30*F I had the block heater plugged in and it was fine.
Another question, does anyone notice if you don't plug in your heater and it is cold outside and you just start driving without the engine warming up, either white, blue, or grey smoke will be billowing out of the pipe? I couldn't tell the color becuase it was dark and I only saw it from the headlights of the person behind me
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 5 Old 11-21-2013, 09:06 PM Thread Starter
I should also add that when it's cold, if I put some throttle to it, it'll seem like it's missing until I let off the throttle. Could it be just because it's cold? The other day it did it to me warm for the first time. It was completely warmed up since I had been driving for a bit. Also, again when cold, if I just press the throttle and let off immediately,(example: pulling away from my house onto the street) it will kind of lope for a second or two until it catches itself again. Any ideas?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #3 of 5 Old 11-21-2013, 11:19 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
dont start it right when the wts light goes out, its a dummy light.
wait atleast a minute before starting.
pull your icp and see if theirs oil coming through the sensor, if their is get a new one. this might be affecting your cold starts.
i had the same issue and replacing the icp fixed it.
how heavy of oil are you using, and how old is it? another thing to look at
and you shouldnt be getting a bunch of smoke out the tailpipe. should be running clean.
also do you start the truck in stock tune and drive it in stock tune until its up to operating temp?
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #4 of 5 Old 11-22-2013, 01:04 AM
Quoted: 727 Post(s)
How many miles on the truck.
White smoke but smells like fuel is oil burning. Replace external injector orings or possible internals of the injector are stuck or internal O-rings are bad.
White smoke that smells kinda sweet (maple syrup kinda) coolant burning
Probably injector cups or head gasket
White/blueish smoke too much fuel. Bad internal O-rings in the injectors. Or poppet getting stuck open dumping fuel all the time.
Corey@CNCFAB is offline
post #5 of 5 Old 11-22-2013, 04:53 AM Thread Starter
Yeah I got some oil in my ICP. I'll change that out here soon. 15W40, about 5,000 miles old and I start it in stock every time
And Corey, It's got about 131,000 and thanks for those tips
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
