Changed glow plugs now has a bad noise! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-18-2013, 11:19 AM Thread Starter
Changed glow plugs on the drivers side of a 7.3l and it started right up but rattled like hell. so i shut it of and the check light is on. Going to try and get the codes on it but and ideas on what might have happien?
04 cc longbed 6.0l. 5" rough country, 35" mastercrafts, s&b intake, 5" turbo back silverline, sct tuner, custom grille, 07 headlights,
oilfieldtrash6.0 is offline
post #2 of 2 Old 11-22-2013, 01:33 AM
Quoted: 725 Post(s)
When you pulled the GP's, oil that was sitting on the head drained into the cylinders and gave you a somewhat hydro locked symptom. Since it started it would've cleared out rather quickly. To be safe, get your ratchet n socket and turn the engine over by hand multiple times by the using the bolt that holds harmonic balancer on. Then start it up.
Corey@CNCFAB is offline
