2001 Glow Plug Controller - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-18-2013, 08:03 AM Thread Starter
BentleyDrivesAFord's Avatar
Send a message via Skype™ to BentleyDrivesAFord
Question 2001 Glow Plug Controller
I am trying to locate where the Glow Plug Controller on my 01 7.3L F350. All I can find is a picture of it and a wire diagram NOT location, help please.
BentleyDrivesAFord is offline
post #2 of 8 Old 11-18-2013, 08:36 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
It's here...
NoRalPh is offline
post #3 of 8 Old 11-18-2013, 08:59 AM Thread Starter
*CONTROLLER* NOT RELAY. thanks anyway.
post #4 of 8 Old 11-18-2013, 09:26 AM
Quoted: 134 Post(s)
WOW! For a New Guy you sure got Attitude
There IS no "controller" (other than the PCM). Is this a California truck you're talking about?
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
BentleyDrivesAFord (11-18-2013)
post #5 of 8 Old 11-18-2013, 09:38 AM Thread Starter
Not sure. I bought the truck in Washington state. I does have the Ambulance package, 2 Alternators and PTO plate on the trans. I have changed all 8 glow plugs(what a *****) and the Relay. Both Delphi products. I am having an intermittent starting problem. It has been to 33deg here once since I changed them and it started no problem. At 40deg sometimes it just cranks, after 3 or 4 turns of the key(with out engaging the starter) the volt meter will finally show a draw. Then it will start normally. So it may be California truck. Not sure.
post #6 of 8 Old 11-18-2013, 10:26 AM
miked.'s Avatar
maybe a bad wire contact. i think there is a sensor for the temperature and that tells how long the glow plugs need to to heat. not 100% sure though.
miked. is offline
post #7 of 8 Old 11-18-2013, 11:06 AM Thread Starter
This is what I am looking for in my truck. Any one. *NoRalPh* I apologize for the attitude it was not my intent. Just frustration to the same answer I get. This is the Controller all have one in one form or another to control the relay.
post #8 of 8 Old 11-18-2013, 12:46 PM
Quoted: 134 Post(s)
Originally Posted by BentleyDrivesAFord View Post
This is what I am looking for in my truck. This is the Controller all have one in one form or another to control the relay.
Someone's given you some Bad info.... This controller, used on CA trucks, do NOT "have one in one form or another to control the relay" on ALL trucks. If you don't see that item, on top of the pass valvecover next to the relay, you Don't have one Anywhere else either (like the Vast majority of us).
If you have a Cold Start problem (and this is the time of year when we see Lots of complaints about it) go through this thread and figure-out what's wrong with the system.
Troubleshooting GPR & GP's
NoRalPh is offline
BentleyDrivesAFord (11-21-2013)
