2002 Ford F250 7.3 dies! - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-18-2013, 06:57 AM Thread Starter
2002 Ford F205 7.3 Diesel.
It started like normal this morning, and did fine till I was about 10 mile down the road, I stopped at an intersection. When I gassed on it to go, it just died... It started right up and idles fine. If I power braked it and got the RPMs up pretty good then it takes right off and drives fine, but if I take off regular it just dies every time. I tried it in reverse and it does the same thing. I changed the CPS, still no change.
Please help!
dkoehn is offline
post #2 of 10 Old 11-18-2013, 08:38 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
No Check Engine light?
NoRalPh is offline
post #3 of 10 Old 11-18-2013, 08:48 AM Thread Starter
No check engine light.....
dkoehn is offline
post #4 of 10 Old 11-18-2013, 09:31 AM
Quoted: 134 Post(s)
That most likely would point to Fuel Delivery then. Thing is, running better at High RPM (where it uses More Fuel) kinda contradicts that...
I'll have to think one that on at Lunch
NoRalPh is offline
post #5 of 10 Old 11-18-2013, 10:31 AM Thread Starter
Once you get going, it runs perfect till you stop! It may die when you stop or when you start driving.
dkoehn is offline
post #6 of 10 Old 11-18-2013, 01:46 PM
Quoted: 134 Post(s)
OK, so here's my new theory
System Voltage....
You need the Alt to be producing maybe. Take a MultiMeter and measure the voltage in the "Outlet" (cig ltr) in the cab. What'da ya got at idle?
NoRalPh is offline
post #7 of 10 Old 11-19-2013, 12:19 PM Thread Starter
It has good voltage. I tried to run the truck a little this morning. It starts up and idles just like always. If you put it in gear and gas on it to take off it dies. If you power brake it and slowly let off the throttle it goes fine then it will drive down the road fine, till you stop then it dies. If I get it going I can drop it in neutral and coast it does fine till I use the brakes then it dies just like that. Tried it in reverse in neutral, and as soon as you use the brakes it dies!!! That's the weirdest thing i've ever seen!!!
dkoehn is offline
post #8 of 10 Old 11-19-2013, 01:15 PM
RadarRider's Avatar
I know this might be old-fashioned, but how about a buzz test? I had a similar problem to this a few years ago. It got to a point where 1 day I was letting it idle getting it ready for work. It sounded like nothing was wrong with it. Then in a flash, the idle changed like it was starving for fuel & died yet again. I thought it would start right back up like it had done time & time again, but it didn't. I tried cranking it to see if the tach would move & it did, so the CPS was out of the question. I ran a buzz & I got IDM codes. It turned out my IDM went on the fritz & then just completely rolled a 7 that last day.
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #9 of 10 Old 11-22-2013, 07:35 AM Thread Starter
On November 20 2013, I was looking around the motor trying to decide where to start, when down in the v of the motor I saw a little retainer nut. I knew what that nut was for! It was the little nut that holds the sensor on the IPR! It had worked off and the sensor was just sliding around on the IPR shaft. I installed the retainer sleeve and retainer nut on the IPR, and it started up and now runs perfect again....
Thanks for the help,
Daniel Koehn
dkoehn is offline
post #10 of 10 Old 11-24-2013, 11:36 AM
Good for you... lucky that little bastard did not roll off and get jammed or fall off and get lost!
mikeprod92211 is offline
