'03 7.3 F-350 Needs Help! - Ford Powerstroke Diesel Forum
post #1 of 29 Old 11-16-2013, 03:37 PM Thread Starter
Question '03 7.3 F-350 Needs Help!
I was going 65 mph towing an empty, light, horse trailer (about 1,500 lbs).
Then the engine started to vibrate violently (heard a tapping noise), I let of the gas, and pulled to the shoulder and on the way, the engine turns off. No warning lights before incident. Had trouble pulling dipstick out--it was bent and scratched. Straightened dipstick out and no oil in crankcase. Left a trail of oil about 200 feet long. Oil coming out of front of engine, say front main seal. No other damage noted. AAA towed F-350 back to farm. Now what?
bobbat is offline
post #2 of 29 Old 11-16-2013, 03:40 PM
Check you HPOP lines I have heard they can go out and they are toward the front.
4x4ihscouter is offline
post #3 of 29 Old 11-16-2013, 03:42 PM
luke7.3's Avatar
Quoted: 24 Post(s)
well.. hoping you didn't lock up te engine. Probably going to need a complete engine rebuild along with possibly new oil lines, hpop, front and rear oil seals... sorry about your truck
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #4 of 29 Old 11-16-2013, 03:49 PM Thread Starter
Engine will crank (I won't even try to start it). What could have happened?
bobbat is offline
post #5 of 29 Old 11-16-2013, 04:48 PM
luke7.3's Avatar
Quoted: 24 Post(s)
Possibly blew front seal under pressure. maybe upload some pics when sun comes up
Luke
luke7.3 is offline
post #6 of 29 Old 11-16-2013, 05:26 PM
timmyboy76's Avatar
your motor will turn off, when low on oil. I hardly doubt your motor is toast. Its a "feature" thats cool about low oil. If oil from the front, probably lost your lpop. Get a Melling 208 and be done ,bud.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #7 of 29 Old 11-16-2013, 06:36 PM Thread Starter
What caused the pressure? I thought crankcases were ventilated?
bobbat is offline
post #8 of 29 Old 11-16-2013, 06:37 PM Thread Starter
Thank you, but what is an "lpop"?
What bent and scratched the dipstick (about 3" from the tip)?
bobbat is offline
post #9 of 29 Old 11-16-2013, 06:55 PM
luke7.3's Avatar
Quoted: 24 Post(s)
low pressure oil pump. and that could have been something f***ing up inside and hitting it under high pressure
Luke
luke7.3 is offline
post #10 of 29 Old 11-16-2013, 07:01 PM
luke7.3's Avatar
Quoted: 24 Post(s)
True but it is common for PCVs to get clogged. Thus resulting in no ventilation and high pressure. Happened to my ol 7.5 460
Luke
luke7.3 is offline
Tags
7.3 , f-350 , powerstroke
