2000 headaches - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-16-2013, 03:24 PM Thread Starter
Angry 2000 headaches
Ok here it goes never done this before but Im seriously lost
2000 F-350 173k miles 7.3
New: Injectors (Refurb from Swamps), UVCH, VC Gasket, IPR, IPC, CPS, HPOP, EBPS and tube, Oil, Fuel Filter, Air Filter. Think that's it.
Problem 1
Using AE doing KOER test shows P0476 (exhaust back pressure control valve)
?????? I assume that's what looks like the rod on the back of the turbo????
I can tell it has a vacuum diaphragm and have sucked (ha ha) on the line going to it and it seems to a) not hold vacuum and b) not operate. BAD?
Problem 2
Again using AE doing a KOEO test results are:
P1271 Cylinder #1 high to low side open
P1272 " #2 " " '" " "
P1277 " #7 " " " " "
P1293 Injector high side open bank #1
P1294 " " " " " #2
??????Don't know what to think. I have done the resistance check from IDM to injectors per GB Remanufacturing - Tech Bulletin #103
and everything was 3.3 ohms where needed and "OL" where necessary.
AE also shows after running for about 5-10 mins a coolant temp of 302f. NOT actual temp block is still easy to touch and radiator hoses are cool. I do live at 8000' elev but I have had a stalling issue since I bought the truck in OK. (Live in NM) Truck runs fine except for extended lengths then the power is gone. Sorry for the long winded report but I have done alot to it and still cant fix the problem, please help
4x4ihscouter is offline
post #2 of 7 Old 11-16-2013, 05:31 PM
timmyboy76's Avatar
dont worry about coolant temp. The AE cannot read it through the OBD.
I'd double check the connections at the UVCH outside and under the valve covers.
Then, remove the EBP sensor and tube..(in fromt of hpop and snorkels to p/s manifold), and clean/replace if neccessary.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 7 Old 11-16-2013, 05:47 PM Thread Starter
Checked connections all reading 3.3 ohms from IDM to injector
New EBP sensor and tube HELP
post #4 of 7 Old 11-17-2013, 01:27 PM Thread Starter
Well Ill go ahead and give an update haven't had much help but appreciate what I got. Started truck this morning everything was normal. Got out on the highway and gave it hell. Turned around about two miles out and noticed a loss of power. Limped it home (barely in 4 low) immediately shut it off and opened the fuel bowl. Half empty. Cycled fuel pump on off on off slowly fuel came up never filled up. Now looking at fuel pump and hutch mod. I'll keep updating hopefully this helps someone else.
post #5 of 7 Old 11-26-2013, 04:41 PM Thread Starter
New update..... replaced fuel pump did hutch mod and pre filter. Prior to test run wanted to verify fuel into fuel bowl. Drained off existing fuel and looked inside and oh hell. Full of trash. New orings and a pressure regulator kit and back up and running. Now dip stick leaks ordered from guzzlemans...............................to be continued
post #6 of 7 Old 11-26-2013, 05:41 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
sounds like you are getting some wrench time.
it always seems stuff needs replacing all at once..
the ebpv sensor is up front, a tube runs from the passenger side manifold to the sensor, which is on the front of the block.
at this point just replace both.
the tube usually gets holes in it and is no good. the sensor has a diaphragm that fails as well.
dieselorings sells these parts. lot cheaper than the stealership.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #7 of 7 Old 12-01-2013, 07:03 AM Thread Starter
Thanks Stroker I appreciate the feedback. I have replaced the tube and EBPS since then and since then developed the infamous dip stick leak. No kidding that thing leaks thats a lot of oil. Ordered diesel o rings kit and have now repaired that. Wasn't to bad JUST DO YOURSELF A FAVOR AND COMPLETELY READ THE INSTRUCTIONS FIRST unlike I did. Got everything torn apart tied off the brush so I wouldn't lose it and let it go. Then Step 5 says to keep the adapter part clean. WHAT oops. I let it lay in the pan. So cleaning it was fun but no leaks after I finished.
Tags
7.3
