problems again Motors dying randomly - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-16-2013, 11:59 AM Thread Starter
broncomitch's Avatar
not sure what to make of this one
I'm driving down the road to have lunch with the wife and it dies in the middle of the intersection, no cranking so i check the fuses and then move the shifter and she fires right up and truck starts seems to run fine then starts missing & the check engine light comes on it dies but fires back up and driving down the road misses a few more times check engine light comes on again but I tryed to pull the codes and there's no codes in the ECU
now sitting in the driveway and I turn the windshield wipers on and the motor dies but I turn them on again and nothings happens but still seems to run fine
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #2 of 14 Old 11-16-2013, 12:22 PM Thread Starter
Died again when the I turned on the wipers.
but its not doing it every time and giggled the wires underneath the dash but nothing happens
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #3 of 14 Old 11-16-2013, 12:22 PM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
Coupla things..
First, the CPS, which one is it? How Old is is? And does this ONLY happen with the wipers ON?
Next, what are you using to retrieve codes? If the light came ON, there Will Be a stored code. Thing is, most code readers don't properly pull codes from our trucks (which are Not, specifically, OBD-II) so, if you've got one of those, generic hand-helds.That's the problem (unfortunately, that's the same thing the Auto Parts Stores use). You need a professional scanner or something with the proper "library" to work right (most here use the AutoEnginuity for proper diagnostics and reprogramming)
NoRalPh is offline
post #4 of 14 Old 11-16-2013, 12:26 PM
Quoted: 134 Post(s)
Most likely a CPS issue, read through this-> Stumbles when it rains??
NoRalPh is offline
post #5 of 14 Old 11-16-2013, 01:47 PM Thread Starter
I just replaced the CPS from napa, the gray CPS.
seems to my problem.
I recorded a video with my motor running and wipers off, then turn them on and every once in a wile when the wipers turn on it stumbles.
Trying to post the video but it's not workin out so well.
Called ford and they won't fix it..
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #6 of 14 Old 11-16-2013, 01:48 PM Thread Starter
Will the one from riff raff work?
The two part numbers are different
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #7 of 14 Old 11-16-2013, 01:54 PM Thread Starter
F7TZ-12KO73-B (one listed in page 2 from ford)
F4TZ12K073C (riffraff/motocraft)
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #8 of 14 Old 11-16-2013, 02:00 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
the napa cps are hit and miss. im pretty sure thats causing your issues, the borg warner cps did this to my truck as well.
napas brand is echlin, but the borg warner one looks the same, i wonder if napa is reboxing BW cps.
id get the delphi hts101 off of amazon or advance auto. smoother idle and more power than the ford cps i used to have .
but a ford cps will work just fine in the meantime.
they said they wouldnt fix it? i wouldnt ever call them again
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #9 of 14 Old 11-16-2013, 06:37 PM Thread Starter
Well, they will.
But not for free
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #10 of 14 Old 11-16-2013, 06:45 PM Thread Starter
And dose the 101 work with the wipers on?
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
