Vacuum leak?? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-15-2013, 07:11 AM Thread Starter
rosshurlow1's Avatar
Vacuum leak??
My defroster lately is my only heating vent, because I'm not building vacuum. I put my finger on the outlet port of the pump and it turned off so I think it's good. Unhooked the outlet at the resivior and plugged it. Pump turned off after 5 mins. Checked under passenger dash and everything looked good. Plugged hub lines still no vacuum, any ideas?
rosshurlow1 is offline
post #2 of 3 Old 11-17-2013, 06:31 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 414 Post(s)
Just because the pump "appears" to be working doesn't mean that it is. Had a buddy with the same issue he just replaced the pump.
LoxDiesel is offline
post #3 of 3 Old 11-17-2013, 07:12 AM
ZMANN's Avatar
Quoted: 1673 Post(s)
5 minutes for it to build enough vac including the reservoir while it's plugged after that seems like long time IMHO
now if u include the HVAC does it not shut off ever ?
are you sure the defrost is because of a no vacuum issue ?
you can try to hook up the HVAC but bypass the esof solenoid also since they can fail to atmosphere that will help isolate
We Miss you Ronnie
ZMANN is offline
