no crank PLEASE HELP - Ford Powerstroke Diesel Forum
post #1 of 18 Old 11-10-2013, 11:44 AM Thread Starter
danf350's Avatar
Send a message via AIM to danf350
Thumbs down no crank PLEASE HELP
my truck is an 02 f350 I've seen a bunch of treads about this an nothing has worked so far im going to run this thing into a tree.I can get it started if I jump the solenoid an it runs fine I have replaced the starter an neutral safety checked all fuses an tightened up the 2torks bolts under the dash nothing.checked batteries they are at 12.55 volts um im at a lose an my rev doesn't want to work if I have the neutral safety switch plugged in if I unplug it it works I thought I got a bad switch so I brought it back an got a new one same thing I installed it in neutral an lined up the lines to calibrate it an bolted it up I don't know im at the end of my rope with this truck please help if you can ty
danf350 is offline
post #2 of 18 Old 11-10-2013, 12:17 PM Thread Starter
danf350's Avatar
an the starter relay dose not click relay #305 which is the trailer tow battery charge relay an #306 delay accessory relay are the ones that click
danf350 is offline
post #3 of 18 Old 11-10-2013, 12:19 PM Thread Starter
danf350's Avatar
I have changed around the starter relay but still no good
danf350 is offline
post #4 of 18 Old 11-10-2013, 03:25 PM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
I think you've discovered the problem though,,,,
Sounds to me like you need to figure what wrong with that NSSW alignment (I wouldn't have thought it would worked unplugged, didn't you need to "jump it out"?). I would try an Ohm Meter to verify you have continuity in P & N. Maybe you're using the wrong marks? I thought mine had a White dot maybe?
NoRalPh is offline
post #5 of 18 Old 11-10-2013, 04:16 PM Thread Starter
danf350's Avatar
aliment
Yea there are two groves in the shaft an it says neutral on the side of the NSS with a line so I put my truck in neutral an lined up the 2 lines an the 2 groves go togeather ill have to see if it needs to be in park when I do it ill have to look itup
danf350 is offline
post #6 of 18 Old 11-10-2013, 04:33 PM
Quoted: 3 Post(s)
You said it cranks when you jump the solenoid so are you getting power to the starter solenoid who you turn the key?
NEW TRUCK
'17
Crew cab
F350
Dualy
4x4
King Ranch
B&W 5th wheel hitch
91 gallon in bed fuel tank
SOLD
02 7.3
CC SB
4x4
P-rot is offline
post #7 of 18 Old 11-11-2013, 04:33 AM Thread Starter
danf350's Avatar
yes it starts
It starts when I jump the seloeniod there is power to the starter thumb:
danf350 is offline
post #8 of 18 Old 11-11-2013, 04:37 AM Thread Starter
danf350's Avatar
no power
The small wire to the seloeniod has no power when I turn the key
danf350 is offline
post #9 of 18 Old 11-11-2013, 04:40 AM Thread Starter
danf350's Avatar
An I mean reverse dosent work if the NSS is pluged in an it dose work if I unplug it
danf350 is offline
post #10 of 18 Old 11-11-2013, 05:32 AM
Quoted: 176 Post(s)
Another way to check for proper alignment is to try to start in R or D (anywhere really)...
NoRalPh is offline
