02' 7.3 stalled at random? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 11-09-2013, 06:18 AM Thread Starter
BrodieBiking's Avatar
So on my 10 minute commute to work yesterday I almost arrived, let off the gas and the truck instantly stalled. I stopped and thought I must have knocked my chip into anti theft. Nope.
Tried to start, truck hesitated then started. Ran for about 5 seconds and stalled again. This happen 3 times after I tried starting again. The. 4th time, it cranked up and drove away like nothing ever happened. Any clues?
Sent from AutoGuide.com App
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #2 of 19 Old 11-10-2013, 04:45 PM
Had the same thing happen to me today. Thought it was the fuel pump. Towed it home and started checking any fuel pump fuses but they were okay. I then tried starting it again and fired right up. Restarted truck 2 more times and no problem. Let it idle for 20 minutes and it didn't stall. Go figure!
Rhzstang is offline
post #3 of 19 Old 11-10-2013, 04:57 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Both of you guys replace your CPS with this Genuine Ford 7.3L Diesel Cam Position Sensor (CPS) - Blue then go from there. It sounds like your problems
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 19 Old 11-10-2013, 06:29 PM Thread Starter
Thanks! Will give it a shot. Happened again today
2002 F350 CCLB DRW
ZF6 SWAPPED!
post #5 of 19 Old 11-11-2013, 08:13 AM Thread Starter
I actually just found one in my glovebox haha! Is this the same one? 02' 7.3 stalled at random?-imageuploadedbyautoguide1384190005.203853.jpg
2002 F350 CCLB DRW
ZF6 SWAPPED!
post #6 of 19 Old 11-11-2013, 08:16 AM
Chapter Director
Quoted: 5 Post(s)
Yes sir thats actually the original black CPS. Some guys say it was the best one of all the CPSs. Good find, but i gotta ask how dont you know whats in your glovebox???
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 19 Old 11-11-2013, 08:30 AM Thread Starter
This was my brothers truck before it was mine. He has a whole bunch of **** in there haha!
2002 F350 CCLB DRW
ZF6 SWAPPED!
post #8 of 19 Old 11-11-2013, 08:33 AM
Chapter Director
Quoted: 5 Post(s)
Ahh i see, im too damn OCD whenever i get a new vehicle i have to completely empty it out and shampoo the crap outta everything so i can start from scratch and maybe find some buried treasures
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 19 Old 11-11-2013, 08:39 AM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
After changing the CPS. If it stalls again ,try to start it , if it doesn't start, unplug the ICP, if it starts right up , you may have a bad ICP.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #10 of 19 Old 11-11-2013, 09:05 AM Thread Starter
What's weird to me is that when the truck dies, and I try to crank it back up,
its almost as it looses fuel pressure and it takes a few times to get it going again.
2002 F350 CCLB DRW
ZF6 SWAPPED!
