03 E350 hard start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-07-2013, 08:30 AM Thread Starter
ihtrucktech's Avatar
03 E350 hard start
Having some issues getting started. its only 40 degrees in the morning and i get a crank no start issue. batteries are new 800 cca, cable connections are clean, new starter, glowplugs and relay just replaced. i have no engine codes.
If i put a booster pack on it then cycle the key it fires right up after a few revolutions. any ideas would be appreciated.
03 ExCab LB; 24V Cummins conversion
, 75hp injectors, 4in dual exhaust, stage1 pump, airdog II, head studs, K&N cold air, gauges, leveling kit, recon cab lights
ihtrucktech is offline
post #2 of 4 Old 11-07-2013, 08:55 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
I would be thinking you have a problem with either getting the current you should TO the Starter OR the starter is requiring more current than it should and only the, added, booster pak makes enough available.
So, the cables and ends (ALL of them, Both sides & polarity) need to be scraped clean, greased, & tightened or replaced (if needed).
Then, if the batteries are all they are supposed to be (maybe have them Load Tested, at a high rate to be sure), I'd be thinking the Starter is just weak. Did it do this before you replaced it?
Have you monitored the Voltage as you're cranking? What is it dropping down to?
NoRalPh is offline
post #3 of 4 Old 11-07-2013, 01:51 PM Thread Starter
Well looking into it I found the voltage drops to 10 cranking. Ended up being my napa batteries that were only 6 months old. Not impressed there but it runs now thanks for the insight.
post #4 of 4 Old 11-07-2013, 02:08 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Thats your problem right there ford specs a minimum of 850 cca. I run 875 cca and have absolutely no problems down below zero
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
