Oil leak - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-06-2013, 09:43 PM Thread Starter
Quoted: 3 Post(s)
Oil leak
Just recently I started getting an oil leak from the back of the engine, bad enough to have visible drips after shut down. I was just reading guzzle's page about the crank case breather (Welcome to guzzle's CCV mod web page). Possibly the issue? Or think it's something more? I don't know how much a bad crankcase breather would leak. HELP!!!
NEW TRUCK
'17
Crew cab
F350
Dualy
4x4
King Ranch
B&W 5th wheel hitch
91 gallon in bed fuel tank
SOLD
02 7.3
CC SB
4x4
P-rot is offline
post #2 of 6 Old 11-06-2013, 10:00 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 17 Post(s)
Where are you seeing the leak? Are you sure it's oil? It could very well be fuel that's leaked into the valley from your bowl o-rings and made it's way to the rear of the engine (more common issue).
How does the valley look?
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 6 Old 11-06-2013, 10:37 PM Thread Starter
Quoted: 3 Post(s)
There is fuel in the valley..... So thinking fuel bowl rebuild in my future?
Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
And if that is the consensus what else should I do while I have the bowl off? Is there anything else that should be done while I'll have the room?
NEW TRUCK
'17
Crew cab
F350
Dualy
4x4
King Ranch
B&W 5th wheel hitch
SOLD
02 7.3
CC SB
4x4
P-rot is offline
post #4 of 6 Old 11-09-2013, 02:53 PM
mhelm's Avatar
Quoted: 7 Post(s)
I have a friend that has a 7.3L powerstroke like mine (99' F350). His turbo pedestal was cracked and pissing oil down the back. Maybe check that also
mhelm is offline
post #5 of 6 Old 11-11-2013, 04:55 AM
Could be turbo pedestal o-rings, a common leak point, or I had this problem and it turned out to be the HPOP line that goes into the LH valve cover. The little o-ring was cut or blew out and the oil leaked into the galley and down the back of the engine dripping when I shut it down. Wipe off the fittings real good and inspect it again after running a short while. It's a very easy fix, but the turbo o-rings take a little time because of the exhaust and air in lines. There are O-rings between pedestal to engine and O-rings between turbo to pedestal.
cheekme is offline
post #6 of 6 Old 11-11-2013, 12:35 PM Thread Starter
Quoted: 3 Post(s)
Oil leak fixed!!!
So it was fuel. I climbed up on my engine and used my remote start to cycle the fuel pump and low and behold..... Fuel coming out of the filter cap. 1/8 of a turn with a 1/2" ratchet later and no leak. Drove it 45 miles this morning and when I got there NO LEAK!!!!
Thank you guys for all your help!
P-rot is offline
