Early 99 Intermittent no crank, no lights - Ford Powerstroke Diesel Forum
post #1 of 1 Old 11-06-2013, 01:15 PM Thread Starter
lookin4myPSD's Avatar
My early 99 F250 will crank and start once, but if I come back later in the day, it will either click-click-click, or not even crank. My batteries are charged, and connected cleanly (to my knowledge), but nothing will happen when I turn the key to ON, with engine off. sometimes the dash lights will light up (battery reading <8 volts), and sometimes absolutely nothing will happen.
If I mess with the battery connections, sometimes it will crank again, sometimes it won't. But no matter what, it always has the problem after I leave it for a while.
All I need is another problem...
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
Tags
no crank , no start , starter
