Map Sensor Port - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-03-2013, 07:25 PM Thread Starter
Map Sensor Port
I just finished installing a wicked wheel and some other mods on my truck, and when I took it out for a drive, the map sensor port popped out of the spider when I started making boost.
It looks like it is pretty loose and is suppose to be a press fit? Anyone else have this happen? Any easy mod that can be done with the spider in the truck?
It looks as though the hole is egged and I can just remove the spider, drill & tap, and install a threaded nipple.
Been searching this issue and came up short, lots of other map problems. I did read about with the 94-97 7.3's moving their map sensor port to the hot side after installing an IC. Any benefit to doing this with the 99-03 7.3's? My edge chip plugs into the map sensor so I don't know if moving the sensor port will cause a problem.
Thanks for the advise and help!!!
Hubbler is offline
post #2 of 6 Old 11-04-2013, 10:54 AM
timmyboy76's Avatar
put a hose clamp on it. There should've been a "press clamp" to begin with.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 6 Old 11-04-2013, 12:43 PM Thread Starter
There is a hose clamp on it. The nipple itself physically popped out of the spider. The hose was still attached to the nipple.
Hubbler is offline
post #4 of 6 Old 11-04-2013, 12:49 PM
timmyboy76's Avatar
damn...tap the hole and install a male barbed fitting
post #5 of 6 Old 11-04-2013, 07:52 PM Thread Starter
Yesh, this is the next step. I am curious if running the map to the hot side would have an upside/downside.
Thanks!
Hubbler is offline
post #6 of 6 Old 11-05-2013, 08:36 AM
CSIPSD's Avatar
The only benifit is a bit quicker boost reading, leading to a bit quicker fueling. Mine has been on the hot side for years. No issues.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
