New Here Need Help 99 7.3 - Ford Powerstroke Diesel Forum
post #1 of 17 Old 11-02-2013, 06:59 PM Thread Starter
I have a 99 7.3 that has developed a problem at start up.
It will start fine but with the check engine light on it only stays on for a minute or so and does not give a hard code but when the check engine light is on the engine seems to have 1/2 power till the light goes out then every thing is fine. this only happens when cold on initial start up.
any help is appreciated.
Thanks
spiffy is offline
post #2 of 17 Old 11-03-2013, 06:35 AM
delta99's Avatar
It's not giving a code with the light on? Is it making any weird noises?
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #3 of 17 Old 11-03-2013, 06:38 AM
Quoted: 144 Post(s)
Feedback Score: 3 reviews
Sure it does....
The code is certainly a stored one, chances are you're trying to use a scanner that isn't capable of retrieving it. You can't use a regular OBD-II scanner on our trucks, you need a professional scanner (Not what the Parts Stores have) to properly diagnose. Most here use the AutoEnginuity for personal use (@$350 w/Ford Enhanced pkg) or just take it somewhere that has the right equipment.
NoRalPh is offline
post #4 of 17 Old 11-03-2013, 07:53 AM Thread Starter
thanks for replying to my problem
one question
if the check engine light is not on can there still be a code in the computer that can be retrieved ?
spiffy is offline
post #5 of 17 Old 11-03-2013, 07:58 AM
delta99's Avatar
Yup...when the light comes on it gives a code. That code will stay there until cleared. If the light goes back out, the code will be stored...still there
delta99 is offline
post #6 of 17 Old 11-03-2013, 08:22 AM
Quoted: 770 Post(s)
TorquePro android app works well for $5 and $25 for a BAFX WiFi Bluetooth obdII adapter.
Corey@CNCFAB is offline
post #7 of 17 Old 11-03-2013, 08:55 AM
Quoted: 144 Post(s)
You know,,, that's a Good Point!
Having the AE, I don't really know much about the App. It certainly won't do anywhere near what the AE will do, but it's apparently a good alternative for someone who just wants a simple code reader that has some of the proprietary and diesel codes that the Generic OBD-II readers library lacks.
This is an Android app that communicates with a BT OBD connector you buy? I've read people having trouble with that communication, is there a Hard Wire alternative?
NoRalPh is offline
post #8 of 17 Old 11-03-2013, 09:49 AM
Quoted: 770 Post(s)
The BAFX model works very well. The cheap $10-15 ones you have about a 50/50 shot of it junk. The app is fantastic and reliable. Sees everything AE does. Just doesn't do CCT or buzz test....yet.
But there is another app that recently came out that does those, but it seems to need a little refining from the reviews. $6 for that one. I'm sure as it catches on and improvements are made to the apps, AE may become obsolete due to the price.
post #9 of 17 Old 11-03-2013, 10:52 AM
Quoted: 144 Post(s)
Come on, you're not that naive - are you?
I know the current "App-Happy" generation thinks an app is the answer for everything but, this is about Information...
What you pay the AE people for is their expertize in Reverse Engineering Fords proprietary information (stuff they don't want to let-out). So you need really smart guys with really good understanding of powertrain management systems to put in a Graphic Interface in a useful package (unlike the app "developers" to are, just now, finding this 10-15yo information that AE had with in Months).
Not to mention all the other technical sub systems (Radio/Nav/etc) they would still have to get around to (for the small group who'd really need it)
No, I think AutoEnginuity will survive the toys & bling of the appsters
It's a serious tool that takes serious development and that needs to be kept current. Not everybody's capable of doing that....
NoRalPh is offline
post #10 of 17 Old 11-03-2013, 10:59 AM
Quoted: 770 Post(s)
I am VERY familiar with AE, I have it. And I think maybe you might be a bit naive toward apps as the 7 yr patent rights run out its very easy to say the least "copy/paste" the software. For the I.T. geniuses out there its very easy for them to do this. Especially when some are possibly former employees/software contractors that engineered the software.
Capitalism at work.
It sucks spending $385 on AE knowing now the TorquePro will give you all the same pid's as AE for $30. :what:
