p1316 99-03 - Ford Powerstroke Diesel Forum
post #1 of 13 Old 11-01-2013, 02:09 PM Thread Starter
p1316 99-03
hey guys i have an 00 7.3 turbo diesel and idk what to do ive started from the bottom and idk where to go. I have a flashpaq superchip/ diagnostic reader my code is p1316. I took down the valve cover i checked the entire thing for continuity and everything was good injectors glow plugs took the harness off everything checked out. the truck is running on 4 cylinders basically i can reach down and grab the driver side exhaust manifold they are cold as hell the passengers is hot. i have my ICP covered in oil inside and out i cleaned it up nicely i cranked it still runs terrible. i tryed unplugging it while running nothing changed at all i put it back in nothing changed i pulled down the idm module and everything looked good connector box and all. i did have a turbo boost sensor code but i noticed it was a little loose cleaned it put it back code went off now all i have is p1316 and dont know where to go thanks for the help
i69dyourmom is offline
post #2 of 13 Old 11-01-2013, 03:32 PM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
The 1316 is really telling you that the IDM is requesting a Buzz Test be done so it can further resolve specific codes. IF the wiring/connectors are really OK, your IDM is probably bad.
Any one around you with a 7.3? Somebody you could do a quick swap with? Any 7.3 IDM will do, as a test, and is the surest/quickest way to call yours bad or not...
NoRalPh is offline
post #3 of 13 Old 11-01-2013, 05:30 PM Thread Starter
idk all a buzz test would do is tell me if my injectors are kickin and i hooked everything back up and checked the connection from the harness pins and everything has good continuity example (center pin ground to first injector good enginge block to glow plug pin good) the pipes are ice cold i dont know anybody with 7.3 i unplug the harness on the drivers side and nothing changes but everything comes out good idk if i had a bad idm wouldnt i get a code? i unplugged the idm and got an error idm code
post #4 of 13 Old 11-01-2013, 05:31 PM Thread Starter
im going to try and find an idm to swap
post #5 of 13 Old 11-04-2013, 10:54 AM Thread Starter
ok i swapped idms with 2 good ones and both did the same thing........... so its not the idm
post #6 of 13 Old 11-06-2013, 07:22 AM Thread Starter
alright well this site was absolutely helpless
post #7 of 13 Old 11-06-2013, 07:52 AM
usteffenhagen's Avatar
You checked your UVCH?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #8 of 13 Old 11-06-2013, 08:30 AM
Quoted: 172 Post(s)
Come On,,, it's not useless, you found it wasn't the IDM - right?
Swapping the first IDM wasn't good enough? You tried a second one? That's PERSEVERANCE!
If you could do a Buzz Test and have the results stored in the IDM's memory (the reason your SuperChip is not the diagnostic tool you think is is...) you'd know even more. As I said, the IDM has a series of tests it does and will give you the results after the Buzz...
But, you want to do it without the benefit of the right equipment, and I think you can really. I would go back to your continuity tests but, this time, start at the IDM connector. You could have a problem before the UCVH plug.
NoRalPh is offline
post #9 of 13 Old 11-06-2013, 02:25 PM
Without the diagnostic equipment you need ( I don't own it either) you are facing an uphill climb. Buzz test would rule out electrical.
You mention having the valve cover down, I assume you ran the truck with it off?? Watching for the oil drain from the injectors. Without either fuel or high pressure oil to pump the injectors, you could get the same no fire on either head. Both hp oil and fuel run to each head in separate lines. Just throwin that out there. Fuel line blocked could give the same symptom.
Seeing the injectors not pumping oil does not rule out electrical though.
JaggedEdge is offline
post #10 of 13 Old 11-08-2013, 05:12 PM
delta99's Avatar
I have hankook currently
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
