03' 7.3 10psi max boost? New turbo - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-01-2013, 01:42 AM Thread Starter
Hey guys, this is my first post but I've been lurking around for a few months
I have a 2003 F-450 with a 7.3L, truck has hardly any guts, just a pig really... I took it to a mechanic and he told me the turbo was bad, I paid to have the turbo replaced and still only getting 10psi of boost (same as before the new turbo) so i did a boost pressure test of the system, no leaks. Replaced the ICP sensor, Air filter, tried disconnecting the wastegate line, replaced the #8 injector (failed test on scan tool) and no dice so far. No cat on the truck....WG seems strong but I haven't wired it shut yet...
I have a new set of up pipes coming, in case a leak is causing this? (but I don't hear any leaks).
I'm reading the boost using a ford scan tool (rotunda with ford SW)
Any ideas what might cause such low boost?
expohl is offline
post #2 of 10 Old 11-01-2013, 06:42 AM
timmyboy76's Avatar
same boat your in...tryn to find my lost pressure for 2yrs.
Try unplugging the redline at wastegate and see what happens. I'm thinking mines' at either the plenums or the collector, but doesnt show soot stains.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 10 Old 11-01-2013, 08:01 AM
Up pipes can cause a huge loss in boost and power. You can usually see soot around them if theyre leaking. If you replace them i would suggest doing the International bellowed pipes. Could also be your intercooler. I'd pull it and pressure test it. the plastic is known to crack expecially in the Cold
Pullnpray is offline
post #4 of 10 Old 11-01-2013, 12:42 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
do yourself a favor and buy a boost leak detector from dieselsite.
that way you can hear all your leaks (you could have a few) and be sure where its leaking from.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 10 Old 11-01-2013, 09:47 PM
timmyboy76's Avatar
why buy a boost leak detector. Go to Home Depot andbuild one yourself for 5 buks.
post #6 of 10 Old 11-02-2013, 05:49 AM
delta99's Avatar
Have you replaced your fuel filters? What's your fuel pressure?
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #7 of 10 Old 11-04-2013, 09:25 PM Thread Starter
I love how over half of the people who replied did even read my post, yeah check for boost leaks, I ALREADY DID, ARE YOU BLIND? LOL...
So it ended up being several issues, the up pipes were leaking bad and I didn't even notice it but now they're replaced it's so much quieter, that was the boost issue but it didn't solve the issue at first because the vaccum line was on the wrong side of the 3 way bleed valve (follow the red line on the WG to the bleed valve)...
So even if you don't think your up pipes are leaking, they probably are!!
expohl is offline
post #8 of 10 Old 11-04-2013, 11:41 PM
Quoted: 270 Post(s)
up pipes leaking is a boost leak
up pipes are a easy diagnosis
whether its soot on the firewall or exhaust fumes/smoke coming from under the hood.
hope you got it fixed.
post #9 of 10 Old 11-05-2013, 04:29 AM
timmyboy76's Avatar
up pipes leaking, is "exhaust" leak :
OP, i think that may be my problem as well...no soot or smoke anywhere ,but think, there leaking....have them dormans' on the bench for a while now
post #10 of 10 Old 11-05-2013, 01:10 PM Thread Starter
i didnt have any noticable exhaust leak, noise, soot, etc once the turbo was out you could see some minor soot on the up pipes though. once i changed them the engine was much quieter, so i could hear it but didnt realize it was leaking ... whoever said an exhaust leak is a boost leak is retarded....
expohl is offline
