Small coolant and oil leak! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-31-2013, 08:07 PM Thread Starter
snapmech's Avatar
Hey all. I have been chasing a small oil leak it appears on the front of the block and leaks onto the steering dampener. Im going to post pictures here in a bit. Im also slowly losing coolant. Very very slowly. Has anyone tries the uv kits to find leaks. Hopefully I can get some help from the pictures. If not WHO in socal wants to come over and earn some beer??
snapmech is offline
post #2 of 5 Old 10-31-2013, 09:09 PM Thread Starter
snapmech's Avatar
Attachment 190369 Attachment 190377Small coolant and oil leak!-1383282544367.jpg
snapmech is offline
post #3 of 5 Old 11-02-2013, 06:32 AM
I was getting a coolant leak from my coolant tank hose just above the radiator. I would only leak when I shut it off because the pressure would get a little higher for a short period. I thought it was an oil leak from the oil pump but it was just coolant picking up residual oil left on the block as it leaked down. Anyway when I put on a coolant filter kit I replaced the lines and that fixed the leak. If that's not it I would check the weep hole in the water pump. It may be coming from there.
2002 f250. bully dog chip. banks wastegate actuator. afe intake. sinister coolant filter. rifraf fuel x over. everything else stock.
dlaratta1 is offline
post #4 of 5 Old 11-02-2013, 10:15 AM Thread Starter
snapmech's Avatar
Thanks I will go check that out in a bit
snapmech is offline
post #5 of 5 Old 11-02-2013, 10:40 AM
belz's Avatar
Quoted: 70 Post(s)
Mine leaked from the thermostat gasket and the temp sending unit. Also check the pump at the lower hose. There is a gasket there also. Mine leaks oil there to but I believe it's from the pan gasket.
Belz
CPA Director
belz is offline
