2001 7.3 just shut off - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-29-2013, 04:48 PM Thread Starter
i was driving down the road and the truck stumbled like running out of fuel cel came on then the truck started running just fine on cel went off. got home and as i went to pull into the drive way the truck just shut off. tried to restart it and it would just crank. waited about 5 minutes tried again and the truck started up. back the truck up and went to finish pulling into the drive way and the truck just shut off again. waited 5 minutes starts right back up again. went to pull the codes today and there are no codes. i have a nice cornwell code reader. where should i start looking?
callmecase is offline
post #2 of 5 Old 10-29-2013, 05:08 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Replace the CPS
dhanna6powerstroke is offline
post #3 of 5 Old 10-29-2013, 06:58 PM
niterunnr's Avatar
My was doing same. Replaced CPS and it was fine. 80 miles later same problem. Was told to get Delphi or Borg Warner CPS this time. Getting one tomorrow. I'll try an update when fixed. Buddy said aftermarket cps are junk.
niterunnr is offline
post #4 of 5 Old 10-30-2013, 02:50 PM
Mod Newbie
Quoted: 20 Post(s)
Ford has an updated one
post #5 of 5 Old 12-20-2013, 11:37 PM
niterunnr's Avatar
replaced ipr valve and fixed all my problems. electric part of valve once hot would short out and shut off causing the valve not to open and let oil pressure into the head and run injectors
