New to the site and in need of soultions - Ford Powerstroke Diesel Forum
post #1 of 1 Old 10-29-2013, 12:45 PM Thread Starter
Question New to the site and in need of soultions
Hi just want to say thanks for all the reading matieral from this site i finally decied to join. My mods are dp tune, 4" down pipe, AFE cai, banks wastgate controler, hid headlights,,, lol and yes engine dies when i turn them on. 8" fabtec with atlas springs, amp running board, everything else is stock.
Problem 1: When i run a buzz test im getting p1271, p1273, p1275, p1277. Only when i run the buzz test do i get theses codes, meaning not under normal driving. Checked my uvch and ohm it ok, everything checks good, pulled inj plugs everything checks good. ohm idm to uvch, everything checks good meaning all my ohms where in tolerance. swaped out idm still the same codes. even ohmed out wires whille moving the harness around... My problem is my truck runs ok with a small miss on that bank and also the temps are 100degress lower comparied to the driverside bank... Also a small knock from that side and nothing got quieter when i pulled the inj plugs granted it was at idle maybe i should of tried it at 1200rpm. Again thanks for reading this so far any help would be apprecieated.
Problem 2:New ebps shows 18.9 at idle.... maybe bad out of the box? or is that ok.
Problem 3: A/c seems to click on and off no matter what setting its on unless its off. Is that common?
Problem 4: Tranny gets hot 230' when its over 100'. replaced my third break light seemed it locks up better now. My TC looks blued like its been getting really hot. Tranny has be rebulit with 20k on it now. Can i get away with just changing the TC, and is there a way i can check pressure to trouble shoot any issues? also what should the pressures be at if i can? i have a Mac taskmaster with all the updates.... Love this thing. I have the 6.0 cooler also and the lines are clean just did a fluid change and it flowed nicly into my bucket... Again ive learn alot from this site.
Problem 5:I bought the truck and it has 556 gears with 37inch tires is this a bad combo?
Problem 6: my graves brake controller stays on even with truck off is that normal?
Problem 7: oil in my valley, not fuel bowl leak or tubing leaking where else would it come from?
Problem 8: I love my Fords and i might be to picky lol thanks for reading this and any advice would be of great help
Powerstrokes&mustangs is offline
Tags
idm , injector , oil , pcm , trans
