Low boost question - Ford Powerstroke Diesel Forum
post #1 of 20 Old 10-27-2013, 09:53 PM Thread Starter
Low boost question
Hey guys I have an 01 7.3 just barely rolled over 100k miles. I've never had anything to monitor boost on the truck until I recently bought the edge juice with attitude. Now I'm used to driving 6.0s and 6.4s for work and their boost is waaaaaaaay higher than my 7.3. While I'm cruising on the freeway about 75 I'm only at like 3-4 lbs of boost. If I floor it and I'm talking pegged out I'm lucky if I see 16 which seems low to me or am I just mistaken. Also ever since I put the programmer in I'm throwing a p1690 waste gate control code which I never had so I don't know if the chip is overriding the truck and it realizes something is different or if it's really just messed up. Any input would be awesome
01lariat4x4 is offline
post #2 of 20 Old 10-27-2013, 11:31 PM
JSchuricht's Avatar
Just cruising there isn't much of a load so boost is low. 16psi at WOT is a bit low depending on circumstances. If you were tuned when you got 16psi then something's wrong. Start by looking for soot around the up pipes and check all your boots are tight and not cracked.
JSchuricht is offline
post #3 of 20 Old 10-28-2013, 04:48 AM
Macon's Avatar
Your truck is throwing a waste gate problem code, and you're making low boost. My first thought would be to check the waste gate system. Might be nothing more than a shorted wire or one a rat chewed up.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 20 Old 10-28-2013, 06:01 PM Thread Starter
Ya I heard I should be pushing close to 25 lbs with a tuner. No evidence of leaks anywhere. Dropped it off at the local power stroke shop today. Let's see what they say!
post #5 of 20 Old 10-29-2013, 04:32 PM Thread Starter
sadly they came back with horrible news. turbo is going out. new stage 1 installed for 1800. should be done tomorrow
post #6 of 20 Old 10-29-2013, 05:11 PM
Macon's Avatar
What did they say about the waste gate code?
2002 F250 CCSB 4x4
Macon is offline
post #7 of 20 Old 10-29-2013, 11:40 PM
JSchuricht's Avatar
Are you saying the shop installed a stage one turbo? I hope it was a 38r for that price.
post #8 of 20 Old 10-30-2013, 05:37 AM
timmyboy76's Avatar
16psi is spot on with a stock truck/turbo.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #9 of 20 Old 10-30-2013, 05:51 AM Thread Starter
The wastegate code supposedly is being thrown because of the chip. The chip is supposed to allow it to build more boost and the truck is recognizing it. Hence the reason why I never threw the code until the chip was installed. However its not building the amount of boost it should. With my tuner on the stock setting I was only pulling 11.84 pounds of boost at wot. On stage 5 they could only get it to 14.6. My buddy has the same set up I do with a stock Turbo and pulls 23 pounds on stage 3. They said I can expect to see mid 20's with the new Turbo. He explained it to me. He said although 100k is abnormally low for a Turbo to go on these trucks but I have to remember this truck is 13 years old! I'm the second owner, I have only put 30k on it but who knows what the first Guy did!
post #10 of 20 Old 10-30-2013, 06:44 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
What are you considering WOT??? Are you talking about hitting the gas from a stop to where you top out or what? Your not gonna see 20-25 psi unless your putting an ACTUAL load on the truck like a big uphill climb or pulling a trailer. Hell i run my truck in 140 tune 24/7 and i hardly even touch 15, even when merging on the interstate or passing. Its not unless im in OD and punch the pedal going up a steep hill where ill see 20+ numbers.
If your throwing a wastegate code did you try unplugging the wastegate hose and see what kind of number your getting after that? Your wastegate is probably just opening too soon. I unplugged mine the other day and ever since i can build boost a whole lot faster than before but just gotta watch your boost when you do that.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
