Can't figure out stuttering problem?! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-27-2013, 12:07 AM Thread Starter
Exclamation Can't figure out stuttering problem?!
Just bought a 2001 psd a month ago and this is my first post on this forum.
I'm having a problem with a hesitation that happens from 1500 rpm to 2200 rpm. It only happens in 4th and O/D under a load. It is most noticable in o/d and once it gets past a certain point it goes away.
The truck has 1500 miles on an oil change with rotella synthetic and about 400 miles on rev-x. Its got intake, stock straight pipe, had a 70 hp chip but i took it off so it could be scanned. It also has 80 hp diy injectors, i guess they are stock rebuilt with bigger nozzles i think. The turbo is a newer gtp38r with an upgrade impeler and no ebpv.
So far I have replaced the ICP(it had oil in it), CPS and done the Rev-x. I took it into a shop to have it looked at and it had good fuel pressure and the turbo and wastegate were good. They did a cylinder contribution test and number three failed. They had it for a week and thats all they figured out.
Any ideas?......
Thanks in advance
*AKWelder* is offline
post #2 of 6 Old 11-04-2013, 08:30 PM Thread Starter
Wow so glad I joined the forum, everyone here is a real wealth of knowledge.
post #3 of 6 Old 11-04-2013, 08:47 PM
Gaius's Avatar
Quoted: 40 Post(s)
Either VC gaskets or #3 injector would be my guess.
Use any oil?
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is online now
post #4 of 6 Old 11-04-2013, 09:41 PM
CSIPSD's Avatar
Any ideas?......
Thanks in advance
First thing...
It was a long weekend for some...
Second thing... you posted in a weird location...
Third...
Maybe you should learn a thing or two about your truck before calling anyone out on how much they know or dont...
Your truck has a 3 speed auto with an overdrive gear, so unless your truck has a super special 5R110 in it, it doesnt do anything when shifting into 4th...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 6 Old 11-04-2013, 09:43 PM
CSIPSD's Avatar
That being said... I love parts replacers...
Check your fuel pressure under load.
Check your ICP pressure and duty cycle under load.
Find out what your injectors are, if there single shots and your running on the split shot tuning, then that could be part of your issue. If there split shot injectors, then that could be your issue as well...
Remove the aditude and people might help you.
Joe
CSIPSD is offline
post #6 of 6 Old 11-30-2013, 10:27 AM Thread Starter
http://m.youtube.com/watch?feature=y...ure%3Dyoutu.be
Here's a video of what the truck is doing. After looking it sounds like it might not be injectors I won't say what I think it is and ill see if you all come to the say conclusion. The mechanic wants to tear into the injectors next week.
