2003 7.3 HELP!!!! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-26-2013, 06:41 PM Thread Starter
niterunnr's Avatar
2003 7.3 HELP!!!!
I have a 2003 7.3 diesel. truck has 230xxx miles. Motor I am not sure. It had a new long block put in about 6 months ago. It was dying and would not start for at least 10 minutes. I replaced the cam sensor. Noticed the icp sensor had oil in the plug so I replaced both and wired back with heat shrink connectors. Now in throttle going down the highway it coughs and will throw a little white smoke. If sitting at an idle or not in the throttle it dies. It will start right back up. It finally threw the check engine light. I got home and threw it on the scanner but the light had reset itself and my scanner showed no codes. Any ideas where to go next? It also has a small amount on oil accruing on top of the intake.. Thanks in advance for any advice. I traded my perfectly fine mustang gt for this new toy and im really starting to think I got in over my head......
niterunnr is offline
post #2 of 3 Old 10-26-2013, 10:26 PM
Quoted: 818 Post(s)
Could be lots of things, but I think I would start with fuel filter. A leak in your HPOP system.
Corey@CNCFAB is offline
post #3 of 3 Old 12-20-2013, 10:39 PM Thread Starter
niterunnr's Avatar
ipr valve fixed the problem
