Srs bulb replacement and coolant leak - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-26-2013, 07:20 AM Thread Starter
rosshurlow1's Avatar
I need to replace my airbag light bulb on the dash, cause it keeps beeping at me. Does anyone know what kind of bulb and how to do it, and I replaced my water pump, thermostat, gasket, housing with a billet one, and I still have a leak there rtv or any advice?
rosshurlow1 is offline
post #2 of 3 Old 10-26-2013, 07:50 AM
alaskan155's Avatar
Quoted: 65 Post(s)
take the thermostat housing off and a green sos pad/lightly sand the housing and wp tell the mating surface is clean, us a M/C thermostat(the built in gasket addresses the problem vs the square shaped o-ring) and a light coat of rtv on the outside edge, then just tighten the bolts evenly.then let it cure for a few hours
thats how i fixed mine after months of leaking.
as for the airbag light, which one? in dash or gauge cluster?
in dash requires replacement module/soldering a new bulb(reg. cab/extended maybe) in and the gauge cluster is just a standard bulb you can get at the parts store.
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #3 of 3 Old 10-26-2013, 08:05 AM Thread Starter
Gauge cluster
